Rear Bumper Backup Sensor Replacement?
9.6K views 4 replies 4 participants last post by  Navyman50
Hey y’all! I’m new to the forum and could use some advice on my 2012 Azera. To put things simply, sometime within the last two weeks one of the four backup sensors on my back bumper fell inside the bumper.
I got under the car and looked up and could see the hole where the sensor should be sitting but it’s not.
Has anyone ever had this happen before and were you able to do the repair yourself? If you weren’t able to do the repair, where did you take it and how much did it cost to fix?
#2 ·
00000732
* Do a seach for your problem. A lot of stuff has been asked and answered.
Thanks,
Welcome aboard.
