61 - 80 of 117 Posts
Its sounding more and more like after the 2009 build the platform has gone down into a more troublesome design. Even after the new tranny/engine issues may have been addressed by 2012 or 2013 on the 3.5L combo.
Another Hyundai would not be in my sites nor a Kia.
Most of us who buy new expect mechanically trouble free drive (parts aren't worn, abused by previous owner etc). In the off chance a part failure occurs then its all smiles at the dealer and out you are with it all taken care without exclusion, oh thats normal, they all do that etc which I have heard from many manufactures. Oh and I don't hear anything. LOL That one really gets me pleading deaf is on an out.
I buy used most of the time since whats weak should have broke by then, wear is minimal if the millage is not too high and had reasonable oil change intervals. I expect there is something I may have to fix but not big ticket items. Many OEM's are moving to CVT (stay away from them). My Jeep Compass has one (on the 2nd now) but they new builds are a 6 speed automatic dumping them. Suburu has gone CVT, god help them as they are killing a great product line. I don't like 2.4L four bangers including the World engine Jeep uses. They are poor on gas for their size and lack towing torque at least with a CVT.
Next might be a eary 2000's truck or SUV which were built on a truck platform with balls. Too much cheap crap built now even the late year CRV has problems
to Remove the water pipe, Should I remove everything from the right side or left side of the pipe so that I can pull it out?
You will need to get intake off and look at which way be easiest to get the job done... new part in hand be great visual aide also as to where you need to go to get it out.
Oil Leak in my 2011 Santa Fe
I took my 2011 Santa Fe for an oil change last week. Following the oil change, there was a big leak from the little hole between the transmission and the motor. Prior to that the SUV ran beautifully. The shop wanted to replace the rear main seal. But thanks to the Internet, I asked them to check the oil pressure sender unit, and to make a long story short, that is what it was. Saved myself a lot of grief and money. Thanks to the kind folks that posted a nice video on YouTube.
My question: Was a bad oil change job blow the oil pressure switch? Or is it just a coincidence???
How Do They Do It?
I've had the oil pressure switch on my 2010 Hyundai Santa Fe (3.5L) break three times. The first time (Sep 2012) it was replaced under warranty (63K kilometres). The second time (Nov 2014) the dealer charged me $470 because it was no longer under warranty (126K kilometres ). And now (May 2017) the dealer wants to charge me another $470. I have about 180K on the vehicle, so it seems the switch is only good for about 60K kilometres or so. The dealer told me they're installing a newer oil pressure switch these days, so clearly there was an issue/default with the old switch. I talked to Hyundai Canada Customer Service and, of course, it took them a week to inform me it wasn't under warranty (Duh, really!). The Hyundai commercial says "The competition wants to know 'how do they do it'". Well, I think I have the answer. Hyundai makes cheap cars with faulty parts and the dealers make lots of money repairing them. A local repair shop said they will replace the switch for $108 (parts & labour). I won't be buying another Hyundai. They've lost me as a customer. And I plan to spread the (bad) word.
Do you really think Hyundai is the only car manufacturer that (allegedly) does this. Do you really think car manufacturers are the only industry that (allegedly) does this?
Do what you think is best for you but don't be shocked if something else similar happens to anything with a different name on it.
  • Like
Reactions: Jpulido09
Similar problem.
Great thread guys. This has helped me a lot!
Investigated similar symptoms that you guys mention and found it was the pressure switch... kinda.
In fact, it turns out to be a crack on the cover where the pressure switch meets the block.
It looks like this is a removable part.
wholesalehyundaiparts.com/p/Hyundai__/COVER-ASSEMBLY---OIL-DRAIN/8496186/211603C700.html
Any body ever replace this? Specifically, is there an easy way to get the water coolant pip out to get the cover off?
Thanks!
Good news.
removed the thermostat housing by unscrewing it from both banks of cylinders. Pulled it away. This gave me room to slide the coolant pipe back and out of the cover.
cover just unbolts and can be popped off.
New one on order now.
Good to know that its not the end of the world if your pressure switch location is cracked!
Has the switch fault ever been fixed in the later years of the 3.5L assemblies. Why they moved the switch from the 3.3L location would be a valid question. 0.2L larger engine and what that gains really are.
Hi guys,
I am bumping this post as it seems to be the best source for this problem. I too had a leaky pressure sensor in my 2010 3.5l Santa Fe. Unfortunately like a few of you here I managed to over tighten my new sensor and cracked the housing. I purchased a replacement housing unit that comes with a new sensor. Part # 21160-3C700. However I have no idea how to replace this thing. A few of you mentioned replacing it but I can't find any good guides or tutorials. The coolant pipe needs to be moved out of the way, but I'm unsure of what needs to be undone for that. Do I need to undo the oil filter housing, thermostat housing etc? Any help would be appreciated. I will try to document or create a video help guide for future
Every time I come to the forums, I get more stressed!
one time when I had the oil changed by my mechanic and i went into my garage the next day and it literally exploded. We always attributed it to bad O-Ring though it was dark and we never really localized it. Since that day my entire engine compartment has oil stains on it so hard to tell. lol. But my engine oil light has never come on, also I check my oil dipstick and have no noted loss of oil....
I know this is an old thread but anyone know the status of the older builds. Seems like a lot of the people in here had the 2010. Did they change the part later or when recalled did they modify the design?? Is there a more reliable aftermarket part?
To the other poster who said that all manufacturers cost cut. I do believe to some extent this is the case but I have to say my Toyota (knock wood) though it basically has a decade old engine when new seems overbuilt for durability. It may suck fuel like crazy and be loud as h#ck but it runs like a champ.
Trying to focus on other parts of life so getting rid of the Santy is not an option currently. Grrr. Only have 15k left on warranty and after 2 VCA motors already plus a lot of hassle, just holding my breath.
Oil pressure switch
Hi,
I also joined the oil pressure switch. The dealer did the job in 2 hours (110.00$ per hour rate) and the piece cost 19.99$ for a big total of 278.00 tx included.
I was happy to ear it was only that, when you see oil under your car, its never a good sign.
The fix should not cost more than 300.00$ if so, then change of dealer or garage.
Mike
I think we is roughly 3hr shop, add 6 lower intake ring, 3 plunum ring, 1 throttle body ring, ans 1 switch..
Easy job, set mind to it and have tools at hand, maybe 1.5hr round trip,, add extra for mopping up liquid oil from valley if it been puking bad
Be glad you not dealing with 3.3L GDI.... I undersold 1, as visual of Hyundai directions was poor,, turn out after intake off, had 2 GDI injector rail and delivery pipe from GDI pump....
Got those off, no way to get wrench or socket on switch,, now I clear off top of transmission of misc stuff, and unbolt crossover from rear of both cylinder head and pull away to release pipe that run through the valley.. now I can remove switch
What is the 3.3L GDI in. My friends bought a SF XL which is the only one with a V6 (3.3L) 2018 on my recommendation. They weren't interest in 4 bangers with two bags of milk engines or Turbo's either. I've been in it as a passenger and quite peppy and bigger than my SF.
This 3.3 GDI was in an Azera,, but "I think" it used in 3rd Gen Santa Fe also
