101 - 117 of 117 Posts
Just bought a 2010 Santa Fe with the 3.5L V6 recently. I was looking for the filler hole for the transmission fluid and noticed oil all around near it, so I immediately thought of this problem (I had read about it before buying the car but during pre-purchase inspection the mechanic didn't notice the problem.. hmm).
Anyway, I'm not a mechanic, so taking the intake manifold off of my "new" car is a bit of an intimidating thought, but I'm willing to try it if necessary.
This video seems to follow the simplified instructions posted in this thread pretty closely, aside from taking the air filter box off:
Is there anything you guys would do differently to make the process easier?
I bought the following parts in anticipation of having to do this at some point:
Beck Arnley 201-1771 Engine Oil Pressure Switch
MAHLE MS19739 Engine Intake Manifold Gasket Set
The simplified instructions in this thread say you don't have to remove the throttle body from the manifold (and I think the video I linked to agrees with that), so am I going to need to replace the throttle body gasket as well? I don't really know how they all fit together.
Also, I own a basic wifi boroscope type camera, so I shoved it down into the engine bay until I located what appears to be the "valley" that fills with oil when the pressure switch leaks. Here are the pictures I took. Pretty neat I think! And yes, there seems to be a bird feather in there... LOL
link removed
I will say, there's obviously a bit of oil in the low points in this valley, and I think the bottom of the clip for the pressure switch has a tiny bit of oil on it... but it's hard to say if this is recent or if this part was replaced before I bought it and they just didn't clean up the oil (there is a bolt missing from that plastic wiring harness\tube that attaches to the manifold, so someone has been in there for something). I just did an oil change about two weeks ago, drove maybe 100 miles or so, and the dipstick is still slightly above the full line (after sitting for a day and a half without being driven), and I haven't seen any obvious drips\leaks on the garage floor under the car.
I don't drive a lot right now (obviously), but I'm going to keep a close eye on the oil level and I'll check that valley with the scope again in a day or two to see if it looks any different. I guess technically I could stick the scope in there and run the car to see if it leaks. I mainly just don't want to go tearing things apart and risking damaging anything else (10 year old hoses or that terrifyingly fragile housing the pressure switch goes into) if this has already been replaced and isn't leaking.
Don't have much to offer in regards to your leak, but I watched that video a while back to prepare myself for the inevitable. lol. One thing I will say if you do tackle this job is to go ahead and replace the spark plugs while the intake is off.
The car only has 60k miles and runs perfectly. For ~$60 or so I can get the NGK Laser Iridium OE plugs, but I'm not sure if I'd just be throwing money away at this point. Most people say their plugs last well over 100k miles. It will take me several years to put 40k more miles on this car.
Going by posts here, I may need to replace the oil pressure sensor again before long... maybe I could wait till then? :)
Still, I am thinking about it... I'm assuming the NGK 9723 plugs at RockAuto for $8.36 each (plus shipping) are correct for this engine?
Do iridium spark plugs actually age? Meaning, do the "years" matter as much as the "miles"?
Hey I know this post is kind of old but my mind is about to explode over this truck. I have a 2011 Santa Fe 3.5L and I’m in the process of changing the oil pressure switch but I also discovered that the housing where the switch screws in is cracked ??. After hours of searching I have the part ordered an on the way. I tried removing the old “oil cover” but after removing the 3 bolts I can’t get it to budge. I read where you said you have to lift it but I don’t wanna break anything so maybe you can go over the technique you used if you still remember how you did it that is. Thanks
Yes please. If anyone has any advice on this please let me know.
I feel like I should summarize my experience here for others to learn from my mistakes, and maybe even for myself if I ever have to replace the oil switch again.
I read the this initial post and watched this video first:
They were both helpful, but I learned that what is in the video is far from the best way to do this.
Tools needed are 10mm, 12mm, 14mm, 6mm hex, phillips screwdriver, 24mm socket, pliers (for removing hoses), flat screwdriver (for removing some conncetor clips). After a little practice (I'll explain shortly) I got to where I could open the hood and have the disassembly done in 10-15 minutes, with all the right tools ready.
Since I don't know all the terminology, I'm going to reference what was done in that youtube video and what does NOT need to be done.
1) The battery connections and the air intake above it do not need to be removed, unless someone wants to chime in saying that this is a big safety issue, it's completely irrelevant to the repair.
2) The air tank doesn't need to be removed from the air hose connecting the filter housing to the throttle, you're going to remove that whole hose anyway.
3) The throttle body does not need to be removed, just remove the 12mm bolt and the electrical connection from the bottom and leave it attached to the intake manifold.
4) The hose bolted to the back of the intake manifold does not need to be loosened.
Once you've gone around and done the rest of the connections, you can lift the intake manifold up and prop it so it is out of your way, you never need to take it or the throttle body out of the vehicle.
5) This one needlessly cost me $300, the fuel injection rail doesn't need to be removed, you can slide a socket in below the rail or use a standard allen wrench with something else for leverage, either way, just remove the piece (I can't think of what it's called) with the injectors and rail still attached. set it over by the oil filter and you now have access to the oil pressure switch.
Finally, as has been mentioned, there are tapered threads and a lot of threads will be exposed. If you buy a 24mm socket, it's probably going to be 1/2" drive, and you won't feel anything at all, something will break long before then. Not knowing about the tapered threads, I tried to snug up the oil pressure switch and the housing promptly cracked. Hopefully if you're reading this you don't haven't already made that mistake, but if you do:
Now is the time to remove the battery and bracket. The thermostat housing needs to be removed so the coolant pipe can come out. It may be possible to get at all the bolts with the battery bracket in, but it was far easier for me to remove the battery than struggle with that.
Since it's not easy to locate the bolts, the attached image will show where they are. (Dorman® 902-5914 - Engine Coolant Thermostat Housing)
The most difficult part of the repair for me was removing the coolant pipe. I finally used a hammer and block of wood to tap against the tab where the pipe is bolted down, doing this I was able to slide the pipe toward the driver's side. Then the oil cover can be removed and replaced. It has an alignment peg so even though all the bolts are removed it needs to be lifted out, it can swivel but won't slide out since the peg will remain.
There is plenty of info on draining the coolant so I won't go into that here.
I hope this information is helpful to someone. At this point, you will have become proficient and removing and reinstalling nearly everything in the top half of the engine compartment.
Great details until the end. How did you remove the housing?
Been lurking around here for a couple years and thought I would share some info and pics on replacing the oil pressure switch on my wife’s 2010 Santa Fe (3.5L). After 73K miles, this is our first mechanical issue of any kind with this car. The switch was not covered under the power train warranty, and after a $935 quote from our local Hyundai dealer, I decided I would make time to replace this $16 part.
The Symptoms
The oil pressure light started flickering, so we took it to the local dealer for a diagnostic. They said I had installed the o-ring on the oil filter cap incorrectly (I do the oil changes) and sent me on my way. A few days later, the oil pressure light was still coming on, and we found oil leaking on the garage floor. Oil was dripping from this area:
(borrowed this pic from here...my stupid phone camera malfunctioned...but the leak looked exactly the same)
We took the car back to the dealer and the diagnosis was a bad oil pressure switch. They also wanted to replace the oil filter housing and the pressure switch housing (both unnecessary, in my opinion). The service guy explained that the $935 repair price was high because the switch and housing are buried under the intake manifold. Lots of stuff has to come off before everything can be replaced.
The reason the oil leaks where it does, is because oil from the leaky switch ends up pooling in the “valley” in the center of the cylinder block.
There is a small hole in the valley, which drains the pooled oil. That’s what eventually ended up on the garage floor.
The Preparation
A couple years ago I bought a PDF version of a service manual for the Santa Fe. It’s about 1200 pages long and has step by step instructions for many things, including removal of the intake manifold. The illustrations (drawings) aren’t great, but the manual is a good reference and helped me prepare for the task.
I was also sort of prepared for a long day or two of work, based on my experiences with replacing lower intake manifold gaskets on a couple of GM 4.3L engines. Thankfully, the 3.5L engine on the Santa Fe involved a lot less time and work.
Tools needed (the ones I can remember, anyway):
· 10mm, 12mm and 13mm sockets
· 6mm Allen-head socket
· 24mm deep socket (with thinnest walls you can find)
· Phillips head screwdriver
· Small flat blade screwdriver to help unclip electrical connectors
· Standard pliers to remove hose clamps
· Needle nose pliers to help remove the clips that secure the wires
· Mechanic’s mirror to help locate a hidden 13mm bolt
The Task
The step-by-step instructions for removing the intake manifold are here. I won’t describe all the steps, and I didn’t take pictures for every step, but here are some highlights and advice:
  • Take lots of pictures. When it’s time to put everything back together, you won’t remember where everything went…trust me.
  • Before starting this project, fire up the engine and then pull out the fuel pump relay. Run the engine until it dies. This way, the intake manifold will be clear of fuel, and it won’t spill out when you remove the intake manifold. This also gets rid of some of the pressure in the fuel line, making it a little easier to unhook the line from the manifold. (Note: I didn't actually do this because I forgot about it until after I started disassembling stuff. But it always worked for GM's 4.3L V6 engines, and I'm assuming it works the same on the Santa Fe engine)
  • Plastic engine cover just pulls right off. Wasted about 5 minutes figuring that out.
  • There's a bracket behind the "surge tank" that has to be removed before that piece comes off. This 13mm bolt is hidden, and you probably won't find unless you have a mechanic's mirror. Here is the general location:
  • Not everything listed in the manual needs to be disconnected or removed. Here’s short list of things I did not remove, which were instructed by the manual:
  1. Large wiring harness and plastic guide on front side of the engine. If you disconnect enough electrical connectors, this can be pushed aside.
  2. Did not touch the ignition coil connectors.
  3. During disassembly, I didn’t remove the injector delivery pipes on top of the lower intake manifold, but I did take these out for reassembly. They get in the way of the lower intake manifold bolts (6mm allen head bolts), and it worked better to torque the lower intake bolts without the pipes there. The pipes come out pretty easy, after removing the 5 bolts that hold attach them to the upper intake manifold (the injectors that are connected to the pipes just pop right out).
  4. Did not remove the metal radiator pipe that goes through the center of the “valley”. The pipe gets in the way of the oil pressure switch, but with a little creativity, I was able to find a combination of sockets and extensions that I could squeeze into the valley and get access to the switch.
  • If you don’t have to remove the radiator pipe, I’m not sure if there’s any need to drain the coolant. Getting access to the drain plug on the radiator requires removal of the plastic underbody shield. It’s not difficult to remove the shield or drain the coolant, but it adds time. I only drained enough to get the coolant level below the intake manifold….may not have been necessary.
  • Probably goes without saying, but keeping things clean is pretty important. I tried to cover any holes that lead to things like fuel injectors and cylinders.
  • The new oil pressure switch came with pipe sealer already on the threads. If you happen to get one without sealer, the Internet is full of opinions on what kind of sealer to use (if any).
Overall, this was a much simpler job than my previous experience with intake manifolds, but it still took some time and patience. Working slowly, it was about a 5-hour job. Would be maybe half that if I had to do it again tomorrow.
Anyone have any advice on how to replace the housing?
Hi guys,
I am bumping this post as it seems to be the best source for this problem. I too had a leaky pressure sensor in my 2010 3.5l Santa Fe. Unfortunately like a few of you here I managed to over tighten my new sensor and cracked the housing. I purchased a replacement housing unit that comes with a new sensor. Part # 21160-3C700. However I have no idea how to replace this thing. A few of you mentioned replacing it but I can't find any good guides or tutorials. The coolant pipe needs to be moved out of the way, but I'm unsure of what needs to be undone for that. Do I need to undo the oil filter housing, thermostat housing etc? Any help would be appreciated. I will try to document or create a video help guide for future
Anybody ever repaired this before? I am at the crossroads and need some advice.
Does anybody have any advice on how to get the housing out? All in this post was great. I got to the part of taking the housing off and I have no clue what needs to be done. " It has an alignment peg so even though all the bolts are removed it needs to be lifted out, it can swivel but won't slide out since the peg will remain. " I am at the crossroads on this one and need some advice.
Visit local Hyundai dealer of choice,, head straight to the parts dept customer counter with VIN in hand..
I have 1/2 an idea what it going to take, 21160-3C700, approx $30 USA, add coolant, and couple o-ring maybe, and gasket for housing, lower intake to head, plenum to lower intake, throttle body ring..
Any news on how to replace the oil cover/ cover assembly oil drain part#21160-3C700?
