81 - 100 of 117 Posts
I need to change the oil pressure sensor in a Santa Fe. Is it necessary to change the intake manifold gaskets?
You is best to replace them, they is expendible part
Dealer found a leak, they say it is the oil pressure switch and the oil filter housing (?). The switch was already replaced once, and not a lot of miles on the replacement. Does anyone know if there is an aftermarket oil pressure switch? I switched to aftermarket struts for the third set since Hyundai's obviously don't last, thinking it's time to do the same for the pressure switch.
Add me to the list of those who cracked the cover assembly. It does seem odd that there would be a lot of extra threads and a small, thin piece of aluminum on the and. Any idea what something like this should actually be torqued to?
Not called in Specifications chart for 3.5L,,,, I did find 5.8 - 8.7 LB-FT in YF Sonata that also use same thread in block for switch to spin into..
I normally apply some TEFLON toothpaste type pipe stuff to thread on switch, and just snug it,,pipe thread is taper, so tighter you go the 2 taper going to split part if install too tight (PERMATEX 592)
I feel like I should summarize my experience here for others to learn from my mistakes, and maybe even for myself if I ever have to replace the oil switch again.
I read the this initial post and watched this video first:
They were both helpful, but I learned that what is in the video is far from the best way to do this.
Tools needed are 10mm, 12mm, 14mm, 6mm hex, phillips screwdriver, 24mm socket, pliers (for removing hoses), flat screwdriver (for removing some conncetor clips). After a little practice (I'll explain shortly) I got to where I could open the hood and have the disassembly done in 10-15 minutes, with all the right tools ready.
Since I don't know all the terminology, I'm going to reference what was done in that youtube video and what does NOT need to be done.
1) The battery connections and the air intake above it do not need to be removed, unless someone wants to chime in saying that this is a big safety issue, it's completely irrelevant to the repair.
2) The air tank doesn't need to be removed from the air hose connecting the filter housing to the throttle, you're going to remove that whole hose anyway.
3) The throttle body does not need to be removed, just remove the 12mm bolt and the electrical connection from the bottom and leave it attached to the intake manifold.
4) The hose bolted to the back of the intake manifold does not need to be loosened.
Once you've gone around and done the rest of the connections, you can lift the intake manifold up and prop it so it is out of your way, you never need to take it or the throttle body out of the vehicle.
5) This one needlessly cost me $300, the fuel injection rail doesn't need to be removed, you can slide a socket in below the rail or use a standard allen wrench with something else for leverage, either way, just remove the piece (I can't think of what it's called) with the injectors and rail still attached. set it over by the oil filter and you now have access to the oil pressure switch.
Finally, as has been mentioned, there are tapered threads and a lot of threads will be exposed. If you buy a 24mm socket, it's probably going to be 1/2" drive, and you won't feel anything at all, something will break long before then. Not knowing about the tapered threads, I tried to snug up the oil pressure switch and the housing promptly cracked. Hopefully if you're reading this you don't haven't already made that mistake, but if you do:
Now is the time to remove the battery and bracket. The thermostat housing needs to be removed so the coolant pipe can come out. It may be possible to get at all the bolts with the battery bracket in, but it was far easier for me to remove the battery than struggle with that.
Since it's not easy to locate the bolts, the attached image will show where they are. (https://www.carid.com/dorman/coolan...rman/coolant-thermostat-housing-mpn-902-5914.html?singleid=133824513&url=999562)
The most difficult part of the repair for me was removing the coolant pipe. I finally used a hammer and block of wood to tap against the tab where the pipe is bolted down, doing this I was able to slide the pipe toward the driver's side. Then the oil cover can be removed and replaced. It has an alignment peg so even though all the bolts are removed it needs to be lifted out, it can swivel but won't slide out since the peg will remain.
There is plenty of info on draining the coolant so I won't go into that here.
I hope this information is helpful to someone. At this point, you will have become proficient and removing and reinstalling nearly everything in the top half of the engine compartment.
Dang wife said oil light flickering on and off. No apparent leaks on my driveway yet.... Is there ANY other reason the oil light would come on? Oil level is full. Oil was changed probably a month ago with no issues until now... Or you think a change is oil grade could do this? I can easily dump and refill....
What's the best 24mm socket to get? Said needs to be thin walled? Or will I get by with a open box wrench?
Need to know......
"Dang wife"
-- OR --
"Dang,,, wife"
As a 3.5L owner in a CM chassis with oil light,, you either have oil filter nipple concern,, should have started as soon as you left oil change place... or you have pressure switch diaphram cracked to where pressure wont open the switch circuit to turn off light...
Years experience tell me (voices in my head) you have pressure switch fault,, switch body might just be moist currently,, but whemn it fully pops, you will just pump oil out of engine at some 50-80 PSI and then it really get messy.. and maybe cost an engine $$$
  • Like
Reactions: DSHornet
Can people chime in as to whether it is a catastrophic fail like quick or slow over time? Mine comes and goes, and for the life of me can't see any oil leaking...
I am going to sound a bit rude here,, but it is what it is---
Are you really serious ??
Light on-off due to cracked diaphram in switch.. it'll start seeping out the switch body for while,, as the valley between banks has a series of cavity that need to flood first cavity, then second, then 3rd, then fourth, before it ever run out of valley..
We typically see them after the switch starts to leak like garden hose and puke out of valley and run off lower bellhousing like it has a rear main puked,, leave line of oil from service aisle to stall as long as it running pumping out the switch body
Relate that to cutting artery or vein,, what happen when you bleed out,, Dead.. same for engine run out of oil
Remedy it now.. cost a lot less than replacement engine
I'm going to get it fixed but I meant in the interim can it be driven... Parts have to come in, a slot has to be booked at the mechanic etc. There is a winter storm warning here, holiday weekend etc... Like my mechanic is 1 hour away no traffic, 2 with. Risk that or tow? That's what I'm getting at. Unfortunately I live in an area where I need a car, so if I'm out of a vehicle for a few days I need to plan accordingly.
We have switch on shelf all time, along with 6 intake ring, 3 plenum ring, and throttle body ring
If it not pouring out on floor, get it there as a night drop and leave it.. fill oil first.. It is when they pouring oil out on floor while running that is big concern,, dont drive it
Been lurking around here for a couple years and thought I would share some info and pics on replacing the oil pressure switch on my wife’s 2010 Santa Fe (3.5L).
Like to thank aa21830, niblake, sbr711 and if he is lurking round here the maker of the vid Mankey. Funny enough I came across this thread 2 years ago and asked if I should be worried... And my fears would come to fruition.
From other places on the web, it seems that this is more common when temps are unusually cold. There may or may not have been a recall on these in Canada. Seems the rubber in the switch shrinks in the cold/becomes more brittle. Mine showed symptoms on the coldest day of the year so far.
I ordered the Beck/Arnley sensor but the part in the box was a Hyundai Mobis part. Made in Korea with part #9475037100. It has the newer part number.
I will only add additional things I think would be helpful. It took me a couple days total because I could only work outside (after work battling sunset), I dropped a bolt which set me back 2 hours, made a few trips to the shops for tools and I was waiting for spark plugs since everything was disassembled anyhow. The problem was confirmed basically once I exposed everything. There was a few ounces of fresh oil in the Vee. I had been getting flickering low oil warning light.
-It is much easier with a LONG 6mm hex. I got short sockets at first and they end up catching the lip of the plastic runner. Interestingly I had 2 VCA motors done prior to this and 2 of the 6 hex bolts in my car were basically loose and not holding squat...
-I could not find any combination of 15/16" socket that would swallow the sensor and still let me get any u joint or extensions on it. I ended up using a combo 12 point wrench. This actually is I feel the better way even though you have to basically turn it only like 1/64 of a turn each time cause you get good feel. This is one time a 12 point is actually better than a 6 point because I don't think a 6 point would allow for enough movement to rotate.
-Reading up on the over tightening freaked me out so actually in the end I used the count the threads method. I took pics of the original sensor in the location prior to taking it out and matched the exposed threads when I put back. Maybe it was just cold but I don't know how you could get good feel using a socket without a visual. If you use a socket it would be very easy to over tighten.
-Finally it is probably worth it to have a bunch of u joints and extensions. It seemed like there was a lot of bolts/nuts that weren't a straight shot and of varying depth.
So it's been almost a week. Car cranked up fine on re-assembly. No Check Engine Lights. No pools of oil in the driveway. Fingers crossed.
oil leak again after another 50K miles...
So I changed out the oil pressure switch on my 2010 Santa Fe about 3 years ago at 75K miles and it fixed the leak issue at that time. The car now has 125K miles and I think the same issue has happened again. Same oil leak area underneath as the previous time. Is there a specific brand of switch that I can get that will last longer than 50K miles? Or are they all about the same quality? Thanks :smile:
We use same switch on other motors I think,, not seeing them puke..
I think the reason for lack of longevity is that it is buried between the 2 banks in the valley, and the heat kills them over time
On the 4 cylinders, they on side of block out in somewhat open air
Hey I know this post is kind of old but my mind is about to explode over this truck. I have a 2011 Santa Fe 3.5L and I’m in the process of changing the oil pressure switch but I also discovered that the housing where the switch screws in is cracked ??. After hours of searching I have the part ordered an on the way. I tried removing the old “oil cover” but after removing the 3 bolts I can’t get it to budge. I read where you said you have to lift it but I don’t wanna break anything so maybe you can go over the technique you used if you still remember how you did it that is. Thanks
Ok, so after replacing the oil pressure switch today at my Santa Fe 2011 3.5 Limited.
After I took it from the mechanic, I see the following symptoms:
1. Check engine light is blinking
2. Not shifting properly, I can now feel it when shifting, its like starting to from the second shift,
3. Car is shaking while idle.
4. When in highway gauge had to go to the 4th level to shift,
5. You can press the gas pedal till the end and it still wont take the gas and start as it used to be.
could someone give any advise what could be the issue with the above?, Im starting to think when he replaced the switch could have done a major damage to the motor itself and the transmission.
PLEASE SOMEONE HELP
Sammy:
The flashing CE light indicates that the engine is misfiring on one or more cylinders, I would take it directly back to the shop. Something is not right, and they need to go back and make it right.
Dion
Dion, after I took it back to him, he did a double check on it and found out that one of the injection wires/hose was loose so he placed it in a right order and now is in perfect condition, even the blinking light is gone... I dont know why but now the engine work and shifting is way much better than it was before... never told me what he did, his only answer was “car is good, come and pick it up”... just hope to continue as is... cause they say “used cars and hookers never trust” lol
About to tackle the oil pressure switch job on my 2011 Santa Fe, will do plugs at the same time. From what I've read you recommend swapping out the related gaskets. Which gaskets exactly do you mean and what are the torque values for the intake and plenum bolts? Thanks!
