41 - 60 of 117 Posts
Ended up going through this process twice this weekend with mixed results and things still aren't quite resolved. I did end up discovering a potential method of discovering this issue without pulling everything apart to see the leaking oil. When I pulled the oil pressure wiring harness connector to the lower left corner of the snap on engine cover I had oil that had pushed it's way up the harness to that point and had oil dripping out of that connector.
I did this job on a bit of an assumption - my car has 67k on it and the oil light started flickering so after a little searching I found this issue and picked up a new sending unit. Before the oil started leaking underneath the engine I started the job yesterday. After 2 hours of so I had everything pulled out and was glad? to see the pool of oil in the valley indicating the failed sending unit. I replaced the part and re-assembled everything. Ended up taking about 4 hours start to finish. Took the car out for a test drive but unfortunately still had the flickering oil light after everything got warmed up.
On the off chance that I hadn't tightened the sending unit up enough or that maybe the new part was defective I dug into it again this morning. After just over 2 hours I had everything back together, finding nothing amiss with the new part. The electrical connector was dry w/o any leaking oil apparent and the threads didn't show any obvious leaking. Unfortunately I didn't clean up the oil in the valley so I couldn't tell for sure if there was a new leak.
After taking it out for another test drive I was unfortunately again greeted with a flickering oil light. I guess the new sending unit could be bad but I am only showing low pressure at low idle after the engine is warm, I am looking for any other suggestions as to where to look next as I am at a loss. Right now I am going to drive it for a few days and see if it starts leaking oil from somewhere else or possibly the new sending unit. I have the procedure pretty much nailed down now so I don't need a weekend to make the swap if necessary.
For those that question the necessity of replacing the intake manifold gaskets, these are rubber and shouldn't need to be replaced just for this job. The parts guy asked me how many miles I had on my engine and said that I had a ways to go before they recommend replacing the upper/lower plenum gaskets.
I would like to thank the OP and those that have responded to this thread for the wealth of information that is present on this issue as it made it a much more comfortable repair to perform. I just wish I knew why I still have a flickering light.
"... am only showing low pressure at low idle after the engine is warm ..."
That is typically when the oil pressure will in fact be its lowest. You've finally warmed up the oil and reduced its viscosity a bit, and at low idle, you've got less action from the oil pump. However, a correctly operating switch will trip at a mere 7 psi, which is practically nothing as pressure goes. Even hot, that's a terrible reading for idle pressure.
Much as I would hate to rip into it again, an oil pressure GAUGE connected at that fitting might be a worthwhile diagnostic.
Mine failed again at 206,000km.
This time I got a hose and extended the oil pressure port out from under the intake and used a 1/8 NPT tee with a pressure guage and the switch.
I initially used an actual oil pressure gauge from canadian tire; first time I started the engine the gauge went to the end of scale >100psi.
Then gauge never returned to 0 reading; great product china tire.
I purchased a 0-300 PSI gauge. On cold start the gauge will go to 110PSI for ~2 minutes. Idle when warm 25PSI.
The oil pressure port should be 1/8" NPT but it is not really, only 2 threads engage, I was able to find a grease hose with a smallish 1/8 NPT thread that worked well.
These 3.5l motors have a high oil pressure @ 110PSI witha 5W20 oil, but the switch should not fail based on that pressure it should have been designed for >300PSI. Perhaps they fail from the high pressure and number of cycles?
I really like the idea of relocating the pressure port to let me get a real gauge hooked up in addition to the switch. Do you have any pictures of how you routed yours 2011_SantaFe? Where did you find your grease hose? Hopefully I can get the parts put together for this over the next few days and tear things apart again this weekend. Thanks for the feedback and for the suggestions for a next step.
Does anything think that the oil being injected back up the switch wiring harness could cause a false reading? When I get it pulled apart again I will test the resistance of the wire to see if it is shifting all the pressure readings.
AEROQUIP be best route.. 1/8-pipe to #4 , use a metric 1/8 pipe die (27 TPI) and chase over the SAE' 28 TPI..
Couple foot of number 4 teflon liner with stainless steel braid, couple fittings, and off to the races..
There is no such thing as a metric 1/8 pipe.
There is however a BSP (british straight pipe) and that is 28 TPI but that is not what the oil switch is.
The oil switch has a slight taper and the threads are definitely 27 TPI and threads completely into a 1/8 NPT port a BSP will not.
I've personally got 30 years experience in machine shops, I will tell you with certainty this is not a BSP thread. I also checked with a good friend of mine who has been re-building engines for 35 years he said it should be 1/8NPT. Oh and I checked it with a pitch gauge
I was able to find a grease hose at princess auto; only one and it was only 18" but it had this b@stard thread that fits into the port in the engine 4 to 6 turns not the 2 you will get with a 1/8" NPT fitting. I then got a 1/8" NPT coupler and second hose and ran that to the firewall where I mounted the gauge and switch. You don't need a ground for the switch the braid in the hose takes care of that for you.
brenwaterys
I hope your switch is just bad because the flicker on idle may be an indication of large bearing clearances. How does it sound? How long did you run the motor with hardly any oil after the switch messed up? Resistance has nothing to do with this circuit it is just a switch (ON or OFF).
Great information. Doing a little more reading around I currently believe that this port is probably a M10x1.0TP threaded hole - a metric pipe thread. I found some comparison specs on this thread:
http://forums.sohc4.net/index.php/topic,103011.msg1167151.html#msg1167151
It also appears that old Air Cooled VW's used this same thread for their brake light switches on the brake master cylinder. I happen to have a collection of old bugs so I will test this theory tonight when I get home. My wifes daily driver is a 1969 Beetle.
Right after the pressure light began to come on I checked the oil level and it has never dropped significantly and unlike a lot of people who have this I have not leaked enough oil to fill the valley between the heads and start dripping on the driveway. I have driven approx. 20 miles with the light barely flickering on at low idle. The light has never come on to the brightness that it has when doing the initial dash light check. At this point I will probably park it until I get a chance to collect the parts. I think my biggest challenge is going to be finding all the correct fittings.
Thanks for the tips sbr711, unfortunately I don't have access to metric pipe dies so I would need to either buy / borrow the right die or possibly locate an M10x1.0TP fitting - whichever method is cheapest / most quickly accomplished as in the mean time I am driving my 7.4L '94 Chevy Crew Cab pickup which gets terrible gas mileage.
I have found a number of M10x1.0 non tapered to 1/8" NPT fittings does anyone know if this would work? Also on your setup 2011_SantaFe did you just screw the switch into a standard 1/8 NPT port on your T fitting? Any issue with that connection leaking?
I would question that chart 1mm pitch is 25.4 not 25.5
The thread pitch diffrence of .059mm is alot like .0023" per thread and i will tell you from experience that I would have seen that like a sore thumb when I checked with a pitch gauge. Plus the diameter is .02" larger that is huge issue, I bet it wont even start in the hole.
You don't show your location, in canada we have a place called princess auto it is like your harbor freight if your in the USA, take your oil pressure switch there and look for a hose that is the same OD's, bring a caliper if you have one, or grab one from the shelf, it is a small 1/8"NPT nothing else.
This thread makes me worry. I have a 2010 with 56,000 miles, and am now a bit paranoid of impending failure. Should I consider changing mine before waiting for leaks? Is there a better aftermarket sender?
@sully
It's a good bit of work considering the risk/reward. As you can imagine, while it's a sore spot for this model year, chances are better that it won't fail than that it will. Still, it's a cheap DIY project as they go in terms of parts. The real hit will be your labor time. I certainly wouldn't go there if paying someone else to do the work.
Just to keep everyone updated I had a chance this evening to get the extension hoses hooked up so I can use a mechanical pressure gauge in addition to the pressure switch and it appears I have more issues. The manual gauge confirms that the oil pressure is low. I didn't let it warm up all the way but by the time it had warmed up somewhat I was below 15psi. From previous information here it looks like 25 is the normal operating pressure, is this correct? My next step is going to be talking to the dealer as I am still under the powertrain warranty. I will start a new thread now since this is no longer on topic for this thread. I would sincerely like to thank everyone that has gotten me to this point.
I certainly sounds like you will be in for an engine rebuild with that oil pressure. Too low even 25psi is also low.
Are you the original owner? How many miles on it.
Oil change frequency as well as oil used would be the primary reason for this happening.
Excellent for you to have your powertrain warranty. Then I guess you must be the original owner since Hyundai cuts the warranty off when it sold. Thats not right...
Just to close out my story in this thread and issue a quick suggestion to anyone reading. Apparently another cause for the flickering oil pressure light is using the wrong oil filter. Make sure that your oil filter is the correct one with the nipple on it and make sure it is installed correctly. I was using an aftermarket filter that didn't have this. While the true reason for the flicker in my case was probably the oil filter my switch had failed as the valley was full of oil when I got it torn apart the first time. However when the new switch didn't fix the problem I ended up having it towed to the dealer and he pointed immediately to the oil filter. Swapped that out and everything is all good now. Long story short - check the easy things first. Thanks for all the help.
Nice and helpful thread.
I came across it when I googled santa fe oil leak - apparently this is very common. I had been dealing with what I thought was a leaking oil filter gasket (after doing 10 oil changes without a problem). I didn't have the time to do this myself (despite the excellent DIY by the OP). My cost was 3h labour plus $11 for the oil pressure sender ($341.03 total - for reference).... Coincidentally, I bought my son a 2007 Toyota Matrix with a leaking oil pressure switch in August (known at the time of purchase) and in 10 minutes I fixed it for $8!
Accessibility to the part (sensor in this case is key) dictates most of the time. Tools on hand and if you can find it (they hide sometimes) to get the job done.
This design does not lend it to easy servicing and when spark plugs need doing its the same issue for the rear ones for both 3.3L & 3.5L engines. An extension for repositioning the sensor might have been an idea to address future sensor swaps if it fails again.
I overtightened and cracked the piece that the oil pressure switch screws onto. does anyone know what this piece is called? does anyone know how to remove it?
I feel like such an idiot right now
Visit local Hyundai dealer of choice,, head straight to the parts dept customer counter with VIN in hand..
I have 1/2 an idea what it going to take, 21160-3C700, approx $30 USA, add coolant, and couple o-ring maybe, and gasket for housing, lower intake to head, plenum to lower intake, throttle body ring..
