21 - 40 of 117 Posts
2010 sante fe oil leak
Just bought a 2010 santa fe 3.5L and have the same problem, mine has 183000 km on it. A private dealer sold it to me and will try to get him to fix this. Hyundai dealer also says front case (aka timing cover) is leaking oil
if you can avoid pulling the fuel injectors... all the better. Apparent dealer says they do these all the time but never have to remove the fuel rail. Seems i cannot get them the seat properly and is literally pissing fuel. I am however getting really good at removing (lifting) the surge tank. Dealer says they have to order as no one needs to stock those LOL
Leave injectors-fuel rail attached to lower intake along with the fuel line attached,,, remove bolts for lower intake to head and lift the assembly off cylinder as a whole single assembly..lay it over by brake master
Update...leaking continues after multiple attempts. Coming from F.I. area closest to driver seat. Can confirm F.I. are lubed and seated properly. Replaced the O rings with felpro "seal kit" (even dealer does not stock as never needed). Nothing leaking when key to on/pressurizing fuel however starts to leak when running. Can now only surmise an issue with intake where it meets FI. that or its not torqued down properly. Will take another step backwards and redo that one...
Sorry for the tardy reply...After many attempts ..I eventually asked the misses to turn over the engine while the surge tank was not attached and stunned at what I found. Turned out the slight click i heard on initial reassembly was a hairline crack on the rear fuel rail where the bolt attaches (driver side). Hard to believe that as this bolt is shouldered by a metal sleeve and I in no means over torqued a 10mm on 1/4" ratchet. See photos. A replacement fuel rail was not an option either at $635 Canadian so I sourced one from a wrecker (complete with injectors) for $150 and 90 day warrantee :)
My interim solution was to sand the area, rub down with acetone, I then used a mini soldering iron to melt the area then wrapped with JB Weld...awesome stuff. Noticed the photo where I only used my mouth (pardon) and put minimal pressure on fuel rail to cause seeping gas through the crack (dark area). Thought it best to replace F.R.instead of repairing. BTW I used blue thread lock on the 10 mm bolts as an added precaution as i did not want a repeat performance.
All in all ... still turned out to be less expensive then going to the "stealership" seeing as my time is free. I may even drop off old rail (minus FI's) to the parts guy from the "nice" dealership as reminder that us "weekend warrior mechanix" can do comparable jobs...eventually
I had found nothing on the web with regards to this specific issue so believe this to be a first and thought better to advise... so hopefully no one else has to go through this. Who knows... this could be a weak point in all "plastic" fuels rails for Santa fe's or larger all Hyundai products :(
Thanks all
I found this thread to be very helpful. Thanks very much to the OP and all that replied.
2012 Hyundai Santa Fe V6 AWD, 40k miles. Had the same leak as the OP. Looks like it might be a rear main seal leak, but the leaking oil up top under the intake manifold and dripping down the side of the engine was a dead giveaway. Made a major mess, drizzling oil at an alarming rate when the engine was hot and running. Oil light never came on, and I was careful to keep the oil up on the quick trip to the dealer. Leaked about a quart in 6 miles.
Dealer kept telling me that it was rear main seal, and then later that I had maybe overfilled the oil, ha. I kept telling them "it's probably the oil pressure switch," and even had a post-it in the car telling the mechanic such. Finally, they brought in a "Hyundai Expert Mechanic." He replaced the oil pressure switch and all is good to go. Took over a week, with a dye test and other bogus diagnosing, ha - you really don't need to clean the engine and then do a dye test when you can just clean and then look at the oil leak, but whatever.
Repair was fully covered under the 5/60 new car warranty. Rear main would have been fully covered under the 10/100 drivetrain warranty. My receipt says part is $12.70 and labor is only $26.70, so $40 total, but it was fully covered.
I think I might buy a spare switch and replace it myself next time.
FYI, and thanks very much again.
Jim
Oh God my 3.5l is leaking just like this - started probably yesterday Im guessing. Today, its really dumping. Parked it in the grass for now.
QUESTION for anyone who did this repair: COULD YOU TELL AHEAD OF TIME THAT THE OIL WAS POOLING IN THE VALLEY?
I took the cover off, and used a flashlight, and mine looks clean and dry from what I can see looking in between stuff.
Is the rear main seal covered if that is the cause? I just want to be able to tell before ripping into the intake, or take it to Hyundai - It just turned 99600miles, so if its rear main and covered, I will have it towed if needed. If its not covered, I have a local mechanic that will do the job cheaper than Hyundai (I'm not attempting a rear main by myself)
ANY help at all appreciated. (Im very mechanical, but like I said, Im not able to see any oil looking where I can see in the valley area.)
Rear main seal is not a fail item with our engines..
Common pee'ing oil leak we see is the oil pressure switch with the 3.5L
Edit your "DRIVES" to reflect what yr, Santa Fe, 3.5L 2WD or 4WD
Edited my info - 2010 SF 3.5l AWD.
So, just to clarify, After looking at everything I can find regarding this repair, it appears you can NOT see a pool of oil without pulling the intake. Is this correct? I have looked as much as I can without starting to rip into this and can see nothing oil wise with the intake and surge tank in place. Closest store that has the sensor is 30 miles away, so borrowing the wife's car tomorrow to go get the sensor, and hopefully rip it apart tomorrow night. Might as well do the plugs while I'm in there @ nearly 100K mi - any preference folks have for spark plugs?
Ngk, Denso, in that order. Iridium NGK is your oem plug in do believe.
If your crafty with a mirror, or have a boroscope laying around (lol) you can see the leak, otherwise it's about impossible to get a good angle at it with everything attached.
NGK IRIDIUM... Pull 1 out of Bank 2 and get code off side, and buy same plug
Crap. No one around here has the NGK or Denso plugs. Only ones I can find by Monday are Autolite iridium. Not a big fan of doing this twice, I guess I will pull a plug from the front and see what kind of shape they are in. I have heard of these going well over 150K before really needing replacement, so maybe I don't need to worry about it right now anyway. (both my kids have 2007 Sonatas with the 3.3 and whatever they came with, still running great at 150K+)
I was planning on trading it in next year, probably fall, anyway. Been a great car, this is actually the first "big" repair of any kind.
You might want to rethink that. Many new vehicle have problems requiring regular visits to the dealer. No other option. I know been there done that. Although the 2010 is the worst build due to manufacturing problem primarily the transmission and AWD rear clutch system it may be that you've addressed them all by now under warranty. I notice a while back Kia SUV was a preferred build over Hyundai in a JD power round up. Although very much the same there must be differences making it a viable choice.
From what I am seeing Hyundai Canada for sure is not consumer friendly or focused on customer relations. Dealers are no better with the highly inflated prices over the same in the USA.
Whelp - I did it. Took me 3.5hrs start to finish. HUGE thanks to the original poster on this thread! Thanks to this thread I was totally prepared, and other than a lot of minor frustrations, it went fine.
A couple notes for the next poor soul who has to do this:
In the pictures at the start of the thread, he mentions using a 24mm socket, extensions and being able to get the sensor without pulling the water pipe out. I spent about 5 minutes trying to figure out how the heck he maneuvered that socket in there.
Here's what I did:
Disconnect the sensor wire and let it fall down.
Take just the socket, slide it butt end first under the far left rear intake runner. It will JUST barely fit. Then slide it above the sensor to the right, let it drop down in, and slide it back over (engaging) the sensor. Now hook on your 1/2" to 3/8" reducer, and I used a 3/8" ujoint, then a 3" extension. The socket does not fit on straight, but it fits on enough to do the job as pictured. Crack it loose and then remove the socket/combo and remove the sensor by hand.
WATCH your hands on the edges of those intake runners on the heads! They are milled aluminum and are VERY sharp, like razor sharp. I sliced my hand in several places and did not even feel it until I saw the red all over everything.
Sop up the oil and blood :) , most of it is in a pool under the front half of the valley you can't really see. Now is a good time to reach down with some paper towels and soak it up. I also soaked it in brake cleaner and sopped that up.
When reinstalling, screw the sensor in by hand, then do the socket dance again to get it on to tighten it. "very snug". you will still see threads - look at the old one, it only threads in about 2/3 of the way before tight. Be careful or you will get the socket "bound up" between the sensor and water pipe (like I did) and have to gently use a pry bar to slide it off.
Other tips:
- Carefully clean the mating surfaces of all gaskets. Head to intake, intake to airbox, etc. I then wiped each with a thin layer of motor oil.
- As stated, only disconnect the electrical connections to the rear, just disconnect anything you need to to flop that electrical harness up out of the way. The factory directions have you disconnect way too much.
- Use plastic bags and a sharpie to label each group of fasteners. I then lay everything out in the order I remove it on the floor in a row. Reinstall is reverse order... No left over parts = good day.
- NO need to remove coolant pipes/hoses from throttle body, just unbolt throttle body, disconnect hoses and wires, and flop to the right.
- If you don't have the correct hex head socket for the intake bolts a T-40 TORX bit will work in a pinch. If you are careful and take your time.
- Use a torque wrench on the intake bolts and follow the torque specs. 7ft-lb first time around, then 17 ft-lbs for the nuts, and 25 for the bolts. In a criss-cross applesauce pattern. :)
- Check, and re-check all your electrical connectors. Make sure they click and are locked in place.
- Be gentle when removing the injectors and rails. Just work it out from one end. Reinstall: clean all the holes, and all the injectors and o-rings, and coat each with oil. (Hole and o-ring). Goes in a LOT easier.
I was going to change spark plugs too - so I pulled the front three to check. They looked PERFECT and were still exactly in spec (measured) at 99,600miles. So I did not change them for the unknown Autolite brand which was all I could get on short notice.
All in all, not that horrible. A bit frustrating sure, but I've had to deal with far worse on other cars! Thanks again folks!!
Thanks!
Thanks for posting the instructions on fixing this. I recently discovered a puddle of oil underneath my 2010 Santa Fe with 75K miles. The picture underneath you posted was pretty much identical to what I saw. I managed to get everything off to expose the 'valley' and sure enough there was a small pool of oil there.
Notes -
I found a 24mm deep socket at Advance Auto Parts that was thin enough to fit between the coolant pipe and manifold at the oil pressure switch to avoid removing the coolant pipe. It was easier to remove and replace the socket with a universal joint in the mix of socket extensions. It's also possible to maneuver the deep socket underneath the coolant pipe over to the oil pressure switch from the right side of the manifold...but it's not necessary if the socket walls are thin enough as mentioned by the OP.
The hidden bolt on the back left of the surge tank seemed to work with a 14mm socket for me.
I went ahead and changed all the spark plugs at the same time with NGK Iridiums.
I find it best to lay out the screws on the floor in the pattern of where they were removed from in order to make sure they go back in the right place when putting everything back....pictures help also.
My father brought his 2010 over yesterday for me to install some winter tires, when we pulled it out of the garage noticed a puddle of oil, took a look and sure enough it was dripping out of the bellhousing. thankfully i found this thread as i would have figured a rear main leak.
was a straight forward job thanks to the advice of this thread.
Also the bolt on the back of the surge tank was a 14mm as 1250flint said.
the sensor itself required a 22mm socket not a 24.. that was both the stock one and the replacement from the autoparts store.
didn't drain any coolant, just unbolted the throttle body.
thanks again, glad i didn't pull the tranny!
Done 3 in last 1 1/2 week... do them in short of 1.5hr.. just got to know where you going
We keep full set of rings for intake and throttle body, along with switch in stock..
