Hopefully this guide will help answer some questions people have.
You will need:
-Interior trim removal tool
-Map light, 2 x T10 LED
-Rear Dome light, 1 x 30mm or 31mm festoon LED
-Vanity light, 2 x 28mm festoon LED
-Glove box light, 1 x 30mm or 31mm festoon LED
-Trunk light, 1 x 30mm or 31mm festoon LED
-License plate, 2 x T10 LED
The removal of the trim is probably the most challenging part of this and is probably a 2/10 in difficulty level.
If any of the lights is not coming out try using a piece of cloth to remove it, specially the license plate ones...
Simply look at the pictures and remove the trim exactly where the picture shows. That way you wont crack or scratch anything.
I have not replaced the vanity lights or the glove box light yet.
You can use Amazon or eBay or whatever and just type the name of the light as it appears in this guide and you'll be given many options. I believe the stock LED are either 5000K or 6000K.
Any questions, let me know.
You will need:
