Unfortunately no pics. Disassembly of everything is pretty obvious once you get the "push pin" clips loosened that hold the door cover to the door. Two partially broke during disassembly, but they seem to be holding fine so far once everything was put back together. there were 4 screws holding the door panel to the door frame, don't recall how many push pins. I removed the switch from the door panel - think there were 5 screws holding it into the door, and the lock out button cover needed to be pulled off for it to come out of door. I then disassembled the switch - 3 more screws and a number tabs in the plastic to release the circuit board from the switch housing. I had to pick up trim tools from harbor freight, so I bought a can of I believe CRC electronics cleaner there. I was worried about the cleaner distorting or discoloring the plastic, that's why I removed the board from the housing and the housing from the door. I sprayed the cleaner under the switches on the circuit board, and into the switch through the two actuating tabs. I then cycled switches a dozen times or more, and probably repeated this at least 3 times for each switch. Then plugged the switch back into connector of door wiring and tested it prior to "declaring" victory and reassembling everything. Total time of actual work, maybe 1.5 hours not including the trip to harbor freight. The trim tools (blue reinforced plastic) were a big help, I was trying with a heaving plastic putty knife and getting no where.
