21 - 23 of 23 Posts
Hi, Just wondered if you installed a reversing camera when you added the Nav unit?
I have the Nav unit as standard fit but wanted to add a reversing camera. I believe I will need to add some additional pins into connector A for the video in and video ground signals (and possibly use the camera power out as well), Did you source additional pins for the connectors and if so do you know the manufacturer part number please?
What triggers the unit to switch to the reverse camera view?
Your install/conversion is the only documentation I can find on the Nav unit and I can't find anything on adding a reverse camera to this Nav unit (even though the Grand i10 did come with a reverse camera option).
Many thanks for any help.
Kind regards,
No that looks like a 3rd party navigation and not a factory Hyundai. The pinout I have is here.
I haven't connected connector B pins 28,29,30. But I don't think any of these are for the door.
Does anyone know what connector B pin 16 is? Is it Battery voltage detect or Back up video detect?
Hi, apologies for jumping in on an old post. Well done on the satnav upgrade, looks great.
I just wanted to ask what head unit this pin out is for? I'm looking for the pin out for 96550-B90524X and can't find anything online, your imagine looks like similar connectors to my unit.
Thank you
I have just installed the factory Hyundai GPS navigation system in my daughters Hyundai i10 2017.
Gone from this.
to this.
Everything working ok I just have a couple of small issues to iron out.
1. The radio doesn't turn off with the ignition even thought I have it connected up to the ACC. Does this work through the CAN bus? Not connected that up? It comes on with the ignition but not off.
2. USB only works as a charger or iPod. Doesn't work with Apple Car Play. This is no big deal as I have a usb cable that it does work with. Would be nice if it work with the factory one though.
3. No navigation voice sound when using navigation.This might be down to the SD card I have.
Anyone wanting to do this I will help you with anything you need help with.
Been looking forever to find this info. I am converting my wife's 2019 hyundai with sat nav (broken) to after market radio. Only discovered all the connections were different when I pulled the radio out and tried to connect the Connects 2 loom.
How do I adapt the airbag, seat belt and hazard connections ??
Any help would be hugely appreciated.
21 - 23 of 23 Posts
