No ac/heat wont blow at all
1.2K views 1 reply 2 participants last post by  AUTOSPARK
Today i had my ac running and switched the speed from 3 down to 1, then poof totally went off and will not come back on at all. I tried replacing the resistor, still nothing. Next tried the blower motor, still nothing. Then replaced all the fuses, still nothing. The compressor is kicking on. Can here the click under the passengers side when turning ac on, but the blower motor is not coming on. Any ideas or solutions?
#2 · (Edited)
Hello and welcome to the forum 00000732
What fuses did you replace? There are two fuses on the blower motor supply circuit. One is the main supply fuse which is a 40A marked BLR on the engine bay fusebox. The other is the ignition supply fuse in the blower relay control circuit which is Fuse 9 on the dash fusebox. If both fuses are OK then I'd next take a look at the blower supply relay which is behind the glovebox to the right of the blower resistor on a LHD car.
Regards.
Scottie.
