2007 2.2 crdt cdx/7
The airbag light is on
1. Will it go off on its own once I have resolved the problem or will it need re-setting with a code reader?
2. If it will need re-setting, can I do this with my cheap OBD2 reader (I can't find this at the moment to test) or do I need a specialist (expensive) reader?
Now, to fix the problem.
I have located the cables going to the seat sensors, which I have read are the most common issue. Cables look OK as do connectors. Is there a way to check that the sensors are working. They just have two wires going to them (red and black). Should there be a change in resistance between them when somebody sits in the seat if I unplug the connectors and put a meter on the wires? And should there be voltage coming from the other side if I put a meter on that (or will there be none as the airbags are disabled?)
Next thing to check would be the seat belt sensors. Any info on how to access these would be appreciated.
