Hi Everyone,
I'm new to the forum but not to cars and wrenching on them. My wife has a 2012 Sonata GLS that was built in 10-12-11. Long story short I had the front struts replaced. There was an issue with getting the right ones. Fast forward 6 months and the clunking is worse and I figured out it's most likely the end links. Sure enough, they're shot. I order new ones and match them to the old ones, no problem. But, then I noticed that the mounting tab on the strut faces towards the rear and the sway bar connection points towards the front. Connecting the end links would mean that they would be in a diagonal configuration which is opposite of what I've known. I thought they always go straight up and down. The link wont fit either way. They barely don't fit in the diagonal configuration.
So, I called the mechanic and he swears he put them in just as they came out. I can not figure how he could've got them in. They are supposed to go up and down. I can not find any definitive pics, not even from the dealer (useless) or Haynes manual. I've go online and have ordered several versions of the struts and none have fit. Tab faces forward but the original/replacement links are too tall. The dealer part number for the strut is 54651-3Q625. The dealer wants $300 a piece. Can anyone please help me find a cheaper aftermarket that will work?
PLEASE AND THANK YOU!!
