2005 Getz 1.1 Error
1.6K views 4 replies 2 participants last post by  Mover
Hi all
Stored Diagnostic Truble Codes (DTC)(Mode 03)
:excl: P0340 - Camshaft Position Sensor "A" Circuit
!Vehicle Area: Power-train (P)
!Area of Vehicle System: Ignition System or Misfire
!Controlled by: ISO/SAE Controlled Code (Core DTC)
!Controll Unit: $11-Engine
Anyone know where this Crankshaft position sensor is located on my model ?
I cant see it anywhere :(
And or any suggestions here ?
Car is very poor on power since this fault showed up.
#3 · (Edited)
Yes your right its the Camshaft and not the Crankshaft position sensor.
Found it.
But the bolt is so rusty it wont come out :(
Gonna give it an other try tomorrow.
Got a tip on how to unplug the plug ? it wont let go no matter what i seam to press pull or push :/
The cable plug that connects to the sensor if you like.
#5 ·
I got the **** thing of and then the sensor came out without too much struggle.
I have cleaned it and put it back in place however the fault is still in place.
Order placed for a new sensor.
Now awaiting delivery.
I will let you know how it goes :)
Thanks for the help so far !
