2004 Santa Fe Humming Noise
3.7K views 2 replies 3 participants last post by  lovemysantafe
When driving on the highway at 55 - 60 mph, there is a loud humming noise which appears to be coming from the front passenger side of my Hyundai. If I go up to 70 the noise gets quieter. Can anybody help me with this?
#2 ·
You should have the front end checked out for possible loose bearings ,ball joints,tierods,as well as an out of balance or bad tire. You could also rotate the tires and see if the noise moves to another corner of the vehicle ,if it does then you know that it's related to that tire.Also check the tread of the tire to see if it's wearing properly that may give you a clue as to the problem. :thumbsup:
Hope This Helps, Good Luck.
