I've seen a couple of posts here mentioning that the headlights can get water in them, and that Hyundai won't cover it under warranty. They say that the headlight bulb will burn out the moisture.
Is this normal? One headlight is completely clear, the other has a lot of water in it. An 8 hour all night drive with the headlights on only dried out one small spot. Anyone think there is a chance Hyundai will actually address this? Its a 2013, and it has been fogged since new.
Next question, anyone know where it is leaking? I'm not far from uninstalling the headlight, and popping it in the over for a few minutes to see if I can melt the seal enough to take the headlight apart and fill it with silicone. I've heard the turn signal bulb seals, but that isn't it. Way too much water, and it happens after a normal carwash. Not much water makes its way into the back of the headlight.
