Tuscon Diesel Power Chip! Which One?
4.7K views 9 replies 8 participants last post by  weebrian
Hi,
Has anyone chipped a 2005 Tuscon CRTD CDX? Or similar model! That's just what I have!
And if yes, which chip?
Any problems?
Where can i purchase?
thanks,
brian.
#3 ·
Hi Brian
I have used one and it makes the Tuc run smoothly and pull much better and all that with a mpg increase too.
Have a look at my attachment it really says it all.
Here are the figures.
HYUNDAI Serie PowerBox Boxtyp
KW PS NM KW PS NM Typ
Tucson 2.0 CRDi 83 113 245 95 129 290 CR-Powerbox
Tucson 2.0 CRDi 103 140 305 120 163 350 CR-Powerbox
Cheers
Itza
#5 ·
I've considered 'chipping' my 2005 (111BHP) diesil Tucson, in particular for towing my caravan. Now all the 'info' for the various makes state that it will not damage the engine - but does that also apply when towing, because the engine is under extreme load. Also are the bhp and torque increases also present under these loads? I have not read anything about these devices when under load and it concerns me.
And a final thougth - in life we are told; you don't get something for nothing -so where does the extra power and torque come from? (esp when we could also expect a little more mpg when 'chipped')
#6 ·
Hi ddix1026
Thanks for the warning but the electronic chipper does not have to go into the |ECM as its an addon that gets fixed between the ECM and the rail on the diesels and what it does is change the signals and its not noticed by the hyundai black box.
All of us using the CR powerbox or Tunex offering take the unit off before taking it in for servicing so nobodys any the wiser..
Itza :460: :460: :460:
#9 ·
Pete2
Don't worry mate the Alhambra is a VW engined and its a different type of diesel engine -We have the best one a Common Rail Diesel.
Come round and try my chipped version you may find you like it
Cheers
Itza
Oh and I have changed my Grill !!
#10 ·
I've been running almost three years using a German unit , the AMH Booster 2, which I believe has now been updated to a slightly neater unit.
As some of the other units, it sits between the ECU and the common rail injector so has no detrimental effects on the management system. It certainly gives an increase in power and torque throughout the range and surprisingly give an additional 2-3 mpg.
As Geoff says, the idea is that it can be removed prior to service so there are no warranty issues.
At about ÂŁ80 at the time I bought it, it has been money very well spent. Also with the option of being transferred to any other common rail diesel with the use of the appropriate vehicle specific wiring harness available from the company.
information in English or German available from :- shop@ihr-tuningpartner.de
