Symptoms:
Any ideas?
- At times, with the car locked and armed, the front passenger door can be opened from the outside, which sets off the alarm. (Haven't tried it from the inside, now that I think about it.)
- At other times, the door won't open from the outside, even when unlocked (via power locks.) The door must be opened from the inside.
- The action of the lock switch on the inside handle seems mushy.
- When disconnected from the cables, the handle and lock switch appear to move normally.
- Pushing and pulling on the lock cable will lock and unlock the latch.
- Pulling on the handle cable will open the latch if unlocked, and will not open the latch if locked.
- Pulling on the outside handle will not fully open the latch, but will release it enough that pulling on the door will swing the latch open.
- Observing from inside the door, the outside handle appears to move the rod properly.
Any ideas?
