Stop Auto AC
1 reading
8.3K views 6 replies 5 participants last post by  MButkus
Hey All;
I have a 2009 Tucson, every time I turn on to defrost the AC automatically turns on. Is there any way to disable this?
Thanks
#2 ·
Not that I know of.
Turning on the defrost automatically turns on the A/C
The A/C unit takes moisture out of the air and the blower passes that air over the windows and windshield
By doing that, the glass clears of fog much faster than just heating the glass.
So, it is an important function of the defrost
#6 ·
I bet there is a way to defeat the default AC logic with the defrost. There is on both my Hyundais. Look in the Owners manual, usually need to cycle the recirc button a few times when in defrost mode until the AC light goes off.
As an example from my Gen Coupe manual, it is the same for the Accent but is not documented. If you disconnect the battery the system will revert back to the AC on with Defrost and needs to be reset with this procedure.
