Since I'm getting no response on this, let me see if I can clarify a bit. This problem just developed as the weather turned warm, but I'm beginning to think maybe that had nothing to do with it. It takes a while to start when cold, in the morning -but not bad. If you shut it off, wait a minute or so and start it back up, it fires right up. It's only after you drive a while, then shut it down for maybe 20-30 minutes, or even a hour or two, that it really has to crank a long time before it will start. It seems like it's not getting enough fuel, or not getting it fast enough. (or maybe it's flooding?) Once it starts, it runs fine. It has 165,000 miles on it. I've recently replaced the fuel pump and the fuel pressure regulator, plus the infamous crankshaft position sensor. It has new battery and alternator, and relatively new sparkplugs. I've got a camshaft position sensor and a purge valve. Should I try them, or am I barking up the wrong tree? Come on guys -give me some input here ...............................
