QUOTE (hawk-I @ Apr 22 2011, 03:50 PM)
index.php?act=findpost&pid=434144
My owner's manual recommends QS 5W-20, but I plan on using QS 0W-20 full synthetic. The reason is that Mobil 1 0W-20 Advanced Fuel Economy advertises a 2% increase in fuel economy. (And my biggest purpose in buying my new Elantra Limited was fuel economy.) If the 2% increase is achievable using Mobil 1, why wouldn't the same hold true for QS 0W-20 full synthetic? I also read that 0W-20 is 100% interchangeable for 5W-20. Thoughts?
How it's made. The only true- by definition, commercially available for retail use FULL synthetic oil is Mobil 1 and AMSOIL.
"Not all synthetic oils are equal. Some give better protection and last longer than others, depending on whether they're formulated with Ester or PolyAlphaOlefin (PAO) stock. Synthetic oils made from the ester class are much more expensive, but are more durable and hold up under hotter temperatures.
Synthetic oils have different base stocks, which comprise some 90% of the oil. The base stock is the actual lubricant The other 10% or so is the additive package. The relative ability of oils to lubricate is determined by the components of the base stock. There are two principal classes of base stocks used in real synthetic oils: synthesized hydrocarbons (PAOs) and organic esters.
PAOs
The base stock materials used today many popular synthetic oils are made of carbon and hydrogen molecules. These
are synthesized from ethylene gas molecules into PolyAlphaOleflns (PAO). Almost all the synthetic oils sold in the stores are made with PAO base stocks. PAOs provide better viscosity characteristics, are more resistant to oxidation and have much better low operating properties than petroleum oils. PAOs are cheaper synthetic oil base stocks, and aren't as durable as the ester class of synthetic oils. Some of the popular brands of PAO oils include Amsoil and Mobil-1.
These are known as a Group IV oil.
ESTERS (Polyolesters)
Organic esters are made by reacting certain acids with alcohols, forming acid esters. There are alcohol diesters and
Polyol esters. This process uses expensive materials and results in lubricants that cost many times more than PAOs.
Only esters are durable enough to withstand the rigors of jet engine operation and they are used in racing and high performance cars. These oils can cost $8 dollars or more a quart. Redline is an example of an ester synthetic oil.
These are known as a Group V oil.
Hydrocracked (sometimes called Hydrowax)
These are petroleum oils that have been hydroisomerized, as it is commonly called. The most stringent level of petroleum oil refining. Much of the paraffin and impurities have been removed and its performance on any number of industry tests is substantially better than it's group two cousins (the regular oil petroleum oil used in automobiles).
Although it is not made from a synthesized, engineered molecule and as such is not a true synthetic oil, it does offer a portion of the benefits you would expect from a true synthetic and in fact is usually sold and marketed as a 100% synthetic product. Hydrowaxes are very cheap to produce, even cheaper than olefins, making them the cheapest of all the synthetics. As they are formulated from crude oil base stocks they aren't a true synthetic. These are known as a Group III oil. Castrol Syntec is known for using this method.
Quality
Premium quality synthetics will blend more than one "species" of PAO and/or will blend these PAO basestocks with a certain amount of diester or polyolester in order to create a basestock which combines all of the relative benefits of these different basestocks.
This requires a great deal of experience and expertise. As a result, such basestock blending is rare within the synthetic lubricants industry and only done by very experienced companies. In addition, although such blending creates extremely high quality synthetic oils, they don't come cheap. "
