P0722, P1529, P0708, P0732,p0733,p0734 2001 Accent Code Help
9.3K views 2 replies 2 participants last post by  beefed88
I have a 2001 accent showing all these codes the problem is that it is showing a range switch code and pulse gen b code. I ohm'd out the gen b and it is within range. could the range switch throw all these codes I would like to just get the right part the first time. Or is the TCM bad so it is showing all these codes??? TIA
#2 ·
QUOTE (beefed88 @ Feb 22 2011, 10:50 AM) index.php?act=findpost&pid=405468
0722 -- inspect the PG-B, replace if out of line.. then be sure to follow up with program #18, Accent VSS Noise..
Clear all the rest, and try again... the slip codes come from bum speed sensor info majority of the time.
The range switch, verify correct alignment of arm and switch body, need long 5mm bolt for align pin.. With GDS, you can go in and verify range switch inputs to TCM in current data..
While hooked up to GDS for the TCM program, scoot over and update the PCM with #52m it is the latest program for Accent w/1.6
#3 ·
ohm'd out pulse gen A as well within range so I just went ahead and bought the range sensor and pulse generators even though I didn't want to neither worked and I made sure the range switch was adjusted, there were larger pieces of metal shavings so I am just gonna toss the car in the trash and call it a day.
