Open Loop Due to Insufficient Coolant Temps and NO power on Acceleration
47K views 66 replies 10 participants last post by  johnaauld
2001 Santa Fe
2.4L DOHC engine
129,000 miles
Hello all, need your diagnostic advice,
I bought the vehicle knowing that it was not running well. It idled quite smoothly but had no power on acceleration but was able drive it home at ~30mph. Never had a timing belt change so I foolishly fixed that before I solved the low power problem. Timing belt change went OK and then I discovered the exhaust manifold was cracked - HUGE crack. Fixed that and installed new cat at the same time. Checked compression and read consistent 127-129 across 4 cylinders. Also installed new before and after O2 sensors at this time. Started her up and sounds good, idles smooth. Hooked the scanner up and read P0115 (something about engine coolant temperature circuit), so I cleared it thinking it must have overheated in the past and that is how the E-manifold cracked.
P0115 never returned.
I have no codes showing now however it appears to be running in open loop and scanner shows "open loop due to insufficient engine temperature" but engine temperature is reading 200 deg F. Also the O2 sensors are not being read, see attached readout.
At this point I am stumped and am thinking I need to check fuel pressure or maybe injectors are clogged.
BUT WHY WOULD IT BE RUNNING IN OPEN LOOP?
All advice is welcomed and thanks.
Tom C
#61 ·
MAF is the one thing that looks off to me too. We don't use lbs/min here in the UK so the numbers aren't familiar to me but what jumps out is the air flow in image 2 is higher than than the other images yet the throttle is closed in image 2. It's difficult to say for sure if that's significant from a static data capture though. Maybe the throttle had only just closed when the capture was taken so there was still air flowing through the sensor. I certainly think some further testing of the MAF would be worth while to try and confirm if the MAF input to the PCM is correct. Perhaps try a test drive with the MAF sensor unplugged to see what effect it has. The PCM should use a calculated substitute value for MAF when the sensor is disconnected.
#63 · (Edited)
Well prompted by Red's observation on the MAF readings yesterday I spent many hours ringing out the wiring between the MAF connector, the PCM, the 'common connector' and ground.
I am confident I had voltage where I was supposed to have voltage, had ground where I was supposed to have ground and had continuity where I was supposed to have continuity. I then dowsed the MAF & IAT with special cleaner multiple times and put it all back together.
I don't know whether I caused more damage or just matured whatever damage already existed but the screen shot from the run after I put it back together shows a lot of dead sensor behavior and the open loop condition returned permanently.
At this point I am thinking the PCM may toasted or at best, sporadic and may have been the fault all along. I wish I could test that theory before spending big $ on a new or used PCM.
What advice can you suggest at this point?
And I certainly thank you all again for your time and interest.
Tom C
#65 ·
I suppose the air tube between the air flow meter and the manifold has been checked for cracks? A light air pressure and soapy water can help identify any leaks.
With the maf disconnected it will run but have some poor driving habits but as RR said it will log a code.
Just has a very quick look at hat last post and the air flow is zero? I find thew best way to test them is by measuring frequency not voltage.
#66 ·
This is better than a Tom Clancy novel. But really? Why leave me hanging like this? That's just cold but perhaps genius. Genius if, after getting folks like myself so interested, that we'd pay money to find out how the story ends! It is now 2019 and Trump has been Pres for two very very long years. There has been nothing to smile about for so long that I believe my face would freeze if I tried now. But, regardless, what ever was the final fix in your situation????
