2001 Santa Fe
2.4L DOHC engine
129,000 miles
Hello all, need your diagnostic advice,
I bought the vehicle knowing that it was not running well. It idled quite smoothly but had no power on acceleration but was able drive it home at ~30mph. Never had a timing belt change so I foolishly fixed that before I solved the low power problem. Timing belt change went OK and then I discovered the exhaust manifold was cracked - HUGE crack. Fixed that and installed new cat at the same time. Checked compression and read consistent 127-129 across 4 cylinders. Also installed new before and after O2 sensors at this time. Started her up and sounds good, idles smooth. Hooked the scanner up and read P0115 (something about engine coolant temperature circuit), so I cleared it thinking it must have overheated in the past and that is how the E-manifold cracked.
P0115 never returned.
I have no codes showing now however it appears to be running in open loop and scanner shows "open loop due to insufficient engine temperature" but engine temperature is reading 200 deg F. Also the O2 sensors are not being read, see attached readout.
At this point I am stumped and am thinking I need to check fuel pressure or maybe injectors are clogged.
BUT WHY WOULD IT BE RUNNING IN OPEN LOOP?
All advice is welcomed and thanks.
Tom C
2.4L DOHC engine
129,000 miles
Tom C
