Not Honking When Locked
17K views 8 replies 8 participants last post by  lovemysantafe
I have a 2011 Santa Fe. I had to take it in for service in April because the shift lock was not acting correctly. Since I have gotten it back, it will not honk when I press the remote button twice. It did before the service was performed. The lights flash properly and the doors are locked, but I still want it to honk sometimes.
Is there something that was turned off that I can turn back on?
#4 · (Edited)
Not sure about Hyundai cars but my last two cars had the option to program the key FOB so there was NO horn sound when the doors locked, just a flash of the park lights. The horn sound is very annoying. Just read through your owner's manual and you should find a section on programing your key FOB. I can also set it up so a single push unlocks all the doors. Most cars unlock just the driver's door as a safety measure so have to press the unlock button twice to unlock all four door, two doors if it's a coupe. :)
However, if the horn isn't working when you push the panic buton, maybe the horn circuit was disconnected by the tech when the car was service. Look for a wire, near your horn(s) that isn't connected. It could be that simple. Good luck.
#8 ·
Check all your doors properly including hatch.
1. In my santa fe it would not honk when you press 2 times on remote when any door of car is not properly closed.
This is rule in my case.
2. Sometimes randomly it decides not to honk when pressed on remote 2 times. I would unlock it and lock it again and it will work or just open one door close it and try and it will work. Strange but it happens and I decided not to over think about it.
