I twisted the end of the fuel line off at the filter inlet while trying to break the filter free. I'm going to try to repair using a short piece of 5/16" brake line, 14mm x 1.5mm thread flare nut and a compression union.
What is the angle of the flare that goes into the filter? SAE 45? AN 37? If I can't get brake line with the correct flare end, I will have to buy or rent a tool or find a shop to make it for me.
Is there a better way to do this fix other than replacing the line as a whole?
Thanks
Update 1:
Bought 60" of brake line and compression fittings from AutoZone for $10. Showed the line and my filter to a couple mechanics and they said the flares matched up okay so I'll start my repair project tomorrow. The brake line says "US Thread/Standard Flare." The ends are double flared. The flare nuts that come with it won't fit the filter. I'll try cleaning up and reusing the old one. Tonight I'll try cutting and bending some of the spare line.
Dorman makes a fuel line repair kit (part# 800156) which is a special order item at AutoZone. They sell it for about $15 bucks and it comes with the 14mm fitting. If it was in-store or I had the time to wait for it if I ordered one, I probably would have bought it.
Update 2:
Well, couldn't get my mini pipe cutter around a perfectly straight area of line when I cut out the twisted part. There was a really slight bend where I managed to cut it off. When I tried to put the compression fitting on, it wouldn't fit because of it. So... went back to AutoZone, got some fuel injector hose and 4 hose bands. Then I cut about 3" of brake line, slipped the nut on, slipped 6" of hose on, double clamped each end then installed the filter. Once everything was connected, the car started up after a few tries. No leaks
The idle seems much smoother now. The gas that came out of the old filter looked dark and there were particles in it.
Thanks
Update 1:
Update 2:
