Multi bin box on DASH lock has broken
1 reading
27K views 25 replies 16 participants last post by  blackfoothenne1962
Can you tell me how to fix the catch. A piece broke off and will not stay shut. This is a 2013 Santa Fe Sport 2.0T
#9 ·
You could but freight is likely slow, try thr dealer but could be expensive. Wrecking yards? And there's 2 trim colours
847452W000NBC
847452W000RYN (black)
#13 ·
Did you ever remove the box? the clip that hangs down broke on mine - 2013 Santa Fe - and it is hard to glue on. There are 2 screws under the rubber pad but I think there are posts also into the dash. I want to remove it, remove the cover and put it back in. Yes I did see it shipping from Korea and refuse to pay for something that is just plastic.
#23 ·
I have a 2016 santa fe sport and I was able to get my top of the dash board storage box out. You take out the rubber mat that is inside the box remove 2 philip screws that are in the rear of the box take a flat blade screwdriver with as thin a blade as you have or something similar and at the 2 front corners of the box slowly pry the corner up a little bit then do the other corner you will be able to see the compartment raise a bit and work your way around each side and it will come out
