Hi Guys,
I live in Australia and have a 2000 LC (built in sep) and I am having the worst time with it. I'll give everyone as much detail as I can and hope someone can help.
I got the car cheap as it had a few issues with running. The problem initially was what seemed like a dead spot in the throttle and bad running.
When I picked it up, the things that had been changed were
- ign coil
- 02 sensor
- spark plugs
- fuel pump
- fuel filter
all these made no change to the car and the issues seemed to get worse. hard to start, no power when throttle pressed, backfiring and complete engine break down to stall.
Things I've done.
- new tps
- new idle control
- new MAP sensor
- new timing belt
- new crank position sensor
- new cam position sensor
- new purge valve
- clean and inspect fuel pump
- throttle body clean
- new center exhaust section
- fixed problem with fuel pump relay
Nothing has fixed the issue. Every part I have gotten is OEM and the car is still playing up. It starts first go now after the new timing belt change which was 40,000 km over due but if you try to accelerate at all the car will bog down and go no where.
After the timing belt was changed I took it for a drive, it felt OK, small backfires here and there, did an ecu reset and the car wouldn't even move. You can rest your foot on the accelerator and the revs will come up after some time, you then press the accelerator and huge induction noise, back fire and the engine will drop in RPM and chug at about 800rpm. Any throttle at all leads to huge back fires, stalling and engine shaking, there are times where throttle flat to the floor does absolutely nothing at all.
Not sure if this has done anything but when I went to pick it up it the battery had been put in reverse and the 100amp main fuse was blown, I replaced that and the car started, I'm thinking the ECU may have been damaged but I'm unsure.
Also there is no engine check light at all, car starts, light goes out after diagnostics complete.....
I really cant put a finger on what this might be, there is no indication of a blown head gasket (oil is clean, coolant is clean) I really am ready to crush this car.
- ign coil
- 02 sensor
- spark plugs
- fuel pump
- fuel filter
Things I've done.
- new tps
- new idle control
- new MAP sensor
- new timing belt
- new purge valve
