Has anyone successfully fixed the fuel overflowing problem?
1 reading
33K views 14 replies 9 participants last post by  sejarzo
#1 · (Edited)
My Sonata has the fuel overflowing problem that seems somewhat common on these cars.
I've searched the forum and found several threads on the topic, but no one seems to follow up and write how they fixed it.
When I fill it I always use the auto fill setting on the pump handle. The pump will click off when it's full and then it will puke out gasoline down the side of the car and onto the ground. I always set the pump on the lowest setting, which sometimes helps prevent the problem. I bought my Hyundai used and it's always had this problem. I never top off the tank. It doesn't do it every time, but it happens frequently and it's really annoying.
I know people recommend replacing the fuel tank air filter, but I haven't seen anyone post and say this fixed the problem. This link shows how to replace it. It's part number 314533K500 and the MSRP is just under $50.
http://www.amdmaddness.com/sonata/tsb/fueltankairfilter.pdf
I'm hoping it's not the charcoal canister, as they appear to be about $200 from Hyundai parts websites.
I'm a DIY'er, so I'll be doing all the work myself.
#2 ·
Im currently at 94K and have luckily never had this issue not even once (knock on wood) and i always use the auto pump at the gas station.
#3 ·
Just to let you know I experience the same problem. If I don't pay attention with the auto pump will overfill my sonata about 50% of the time. As of now my solution is listen to the pump and stop filling right when the frequency changes.
I would also be interested in a solution if anyone has one though.
#5 ·
I have a coworker that had a similar problem on a different model.
He described the problem as more of a 'burping' of the fuel, so it may be a significantly different problem.
He would fill up the car, and at the last moment, just before the pump would 'click' off, the car would 'burp' or gently splash fuel back out of the fuel door and down the side of his car.
His mechanic finally found that a vent that allows the pressure to release, was stopped up. The pressure would build from filling the tank, and then fuel would be released back out around the nozzle.
/good luck
#6 ·
That vent is the fuel air filter, a.k.a. charcoal canister. Sometimes the check valve within the canister stops working properly. Typically the fix involves replacing that canister at a not insignificant price. What was the exact repair made to your coworker's vehicle? Was it a repair or replace? If it was a repair, what exactly was performed during the repair? That's what has never been answered before on any prior post regarding this topic. Inquiring minds want to know! ;)
#8 ·
I'll confirm when I next see him (next week-ish). I think his approximate comment was, "they replaced a part and I didn't see the issue again." He did indicate everything was covered under warranty, so it might be a dead end lead. He was only 3 tanks into owning it at the time, so the dealer's option was fix it or own it.
#10 ·
I thought it was my car, but I think it's more about the gas nozzle. Rented a Kia Soul (horrible car) and this happend traded it in for a convertible mustang and it did the same thing when filling up.
as a response in another thread, when i realize it's getting full, you can hear it, I pull out the gas nozzle put it back in and fill up slowly. Has not happend to my car since.
#12 ·
Yeah that sounds about right. The check valve is integrated into the fuel air filter and unless it is a simple clog that can be cleared, the entire filter canister needs to be replaced. Thanks for the information.
#13 ·
Having this same issue on my daughters 2010 Accent GLS. It burps up fuel after the fuel shuts off on the pump. Which exact part do I need?
Vapor Canister
Vapor Canister Purge Valve / Solenoid
Vapor Canister Vent Valve / Solenoid
#15 ·
We bought a 2006 Sonata early in 2015 with less than 39k miles on it (a true "grandpa car") and for the first few weeks, it had the problem each time i filled up. It then went away has not returned in over a year. All I could conclude was a small clog had developed, maybe just enough to cause the issue, but something managed to dislodge it. I wonder if that's common.
