Gasoline Stablizers?
2.8K views 19 replies 10 participants last post by  barrywpg
I thought I was being smart filling up mid March before the Covid shutdown hit in our province. But now I'm not so sure.
In the 6 weeks since I only used about 1/4 of a tank. Starting to wonder about the gas degrading if I go another 3 months before
adding more.I bought some Sta-Bil but haven't added it yet.
Any downside to using it in a GDI engine?
After this, once I get down to about 1/4 tank I think I will just add 15 liters or so at a time.
Thanks
#2 ·
I can’t think of any downsides, but in a sealed fuel system on obd2 cars the fuel is not exposed to outside air and it will last for many months. IMO if you’re storing a car for 12 months or less I wouldn’t bother. If storing more than 12 months then I’d suggest a fresh tank of fuel with a fuel stabilizer.
#9 ·
Ethanol separates from the gas in a short period of time
Not according to THIS study. The study was performed for the small engine industry and I would speculate that in new cars with the high level of sealed fuel systems the time is even more.
In my opinion the 2.4L with twin overhead cams is a performance engine , so I use super. No ethanol, and its cleaner than the regular.
This has been debunked many times. The "no ethanol" will give better MPGs, but there is a cut off of price difference versus mpg gains. I know because I did an extensive test when I could get non ethanol gas in regular grade. Now only the mid grade is offered as non ethanol - at least in my locallity.
#7 ·
It's the other way round. Ethanol is slightly heavier than petrol so if separation occurs a higher octane product will fal to the bottom. Saying that the stoich air fuel ratios are also very different and the ethanol will burn lean. 6-12 months won't be a problem. Isn't it ironic we have the cheapest fuel in decades and can't use it.
#11 ·
Ive always kept the fuel tanks on anything I own (cars, trucks, motorcycles, mowers, generators, pressure washers etc) full to minimize the chance of condensation build up and water in the tanks. If Im not going to use them for more than 6 months Ill put some "Sta-Bil" in the tank. Then top off after use.
Ive had bikes and a generator that only gets run every 12-15 mo. and never a problem.
#12 ·
Condensation, when it occurs, forms at the top...there is little you can do to eliminate it happening. Dense vapor may help...the fuel system is design to deal with it to a point.
#15 ·
My point is, it's near impossible to maintain 100% fuel in a tank...it may be pointless to try. It really depends (surmising here) on how well the dense vapor inhibits the condensation. :unsure: Something you assume all your life doesn't make it true. Toilets don't flush in the opposite direction in the Southern Hemisphere compared to the Northern! :geek:
#16 ·
I also see your point. Fact is for the time people are "storing" their vehicles due to COVID. Condensation wont become a issue of concern and wont cause corrosion in that time frame. My stuff gets stored in a temp controlled basement with a dehumidifier. LOL so im good either way
#18 ·
Absolutely. Also the fact when I have to drive somewhere the traffic flows free. Ah what it used to be 40 or so years ago.
Very true here too in NJ,but,the people on the highways are driving faster and even more moronic than they used to.Some days its like I am on a race track.
  • Like
Reactions: Symatk
