Front Brakes Clicking Sound
8.7K views 7 replies 6 participants last post by  craigbrooks
I just replaced rotors and pads on my 2007 Sonata. I got top of the line premium rotors and ceramic pads from Napa. Cleaned the oil off the rotors and gave them a light sanding before installing, made sure that the caliper bolts moved freely and the caliper pistons were not seized and also used new hardware kit (springs?) that came with the pads.
Everything seems to be ok, except for a clicking sound that occurs on hard breaking as the car is coming to a stop. I think its caused by the pads moving within its mounts (I did notice it was very easy to slide these pads into the mountings, more so than in previous pad replacements).
Reading from other posts I think this is still safe, but the clicking does bother me, should I use pad adhesive to stick the pads to the caliper?
tnx
#3 ·
Hi amentac.
One of my Sonata's does this as well. Just as the car completely stops, there is a click sound. I believe as you do that the pads are moving slightly in the carrier as there is a bit more play there than there was with the previous pads. I do not believe that this will affect performance in any way.
#4 ·
Napa pads never fit right. Usually they're too big but I'm not surprised that they're too small. Also the hardware may not be correct. Had that happen before where I'm not sure what caliper they had in mind when they put the hardware in the box. You can try taking them back to Napa and see if they will warranty them.
#7 ·
Well, I couldn't live with it...and I found the problem.
The sound was coming from the left front brake. I took it all apart and removed the rotors. You know the two little screws that hold the rotor to the hub? The ones that you drill out the first time you ever do your brakes and never replace? It turns out that one of them was not completely drilled out and there was a bit of metal sticking out. When I mounted the new rotor I didn't match the screw holes on the rotor with the ones on the hub, so that bit of metal was pushing the rotor slightly out of place. All I had to do was remount the rotor making sure to match the screw holes and the noise is gone!
