No, your '07 has it, too.
It's not the only possible reason for that noise, and you'll want to look around a bit before diving into that one in particular. The additional (or actually, the original) symptom you should be noting is excessive vibration at idle.
Replacement isn't trivial. It involves a LOT of parts, eventually ending in the dropping of the engine/transaxle. Pretty ugly, and I don't know of a way to do it easily -- you're pretty well stuck with 'by the book'. Would have to look up the shop hours tomorrow, but you don't want to know. The thing is a little vacuum operated gadget with an electronically operated solenoid on the side that controls the vacuum to the mount.
As for troubleshooting, you first need to see if there's power to the mount's solenoid. We'll assume that your idle speed isn't hosed up and is below 810RPM (this thing is controlled by RPM).
With brake applied and engine at idle (see above), shift to drive. Plug/unplug the two pin connector on the solenoid. You should notice a definite difference in vibration.
If you don't notice any difference, move to neutral or park. Check for 9~12V between the pins of the connector. If not found, it's a wiring or fuse issue.
If there's between 9 and 12 volts there, get the RPMs up to 1000 or more and check across the connector again. NOW what's the voltage? There shouldn't be more than 2V. If there is, you've got a control or wiring issue.
Next you have to be sure there's vacuum up there to operate it. First you have to apply more than 7 psi of vacuum to the mount to check for leaks (though you may not have anything at hand to do that) through the lower hose, and then cap off the vacuum source, to see if it holds a vacuum for at least 20 sec. If it won't hold a vacuum, well... either the hose is hosed, or the mount is toast. You should notice a difference in idle vibration with/without the vacuum applied. If you don't, it's toast.
If it holds a vacuum and you DO notice the difference at idle with vacuum applied or not, stick a vacuum gauge on the upper hose to see if you've got any vacuum there. If not, either things are kinked or you've got a vacuum leak along the way that I would think would be causing other issues long before you need to worry over the mount. If you do have good vacuum there, it's the solenoid on the mount that needs to be replaced.
