Charcoal Vapor Canister Filling Issue
54K views 10 replies 6 participants last post by  JonBoy470
This is the ticket. I had the exact symptoms on my old 99 Accent. Pulled a canister and purge valve from a pick a part junkyard for a few bucks, solved the problem entirely. As an interim fix (before I got to the junkyard) I removed the hose clamp at the canister for the tank to canister hose..that let me reach under the bumper and pull the hose off at the gas station so I could pump gas. Then reconnect before I drove off. If it's all done with the ignition off the ecu won't throw a code for evap leak...
