Brake Pad Thickness
6 reading
6.8K views 6 replies 5 participants last post by  Perry Manessis
i just took a look at my front brake pads.. it appears as if they are about 1/4" thick... i have also noticed that my rotos are a bit "grooved" (although not extensively gouged)... when i run my finger outward from the center of the rotor, its a tiny bit "bumpy"..
what is correct normal thickness for pads and it is wise to have the rotors TURNED or should they be replaced?
i bought the car used with 27k miles on it, now at 30k (in about 2.25 months or so).. i obviously notice this more on the highway when i have to break from higher speeds...
thoughts?
note - i know as much as if the brakes are squealing or even worse, grinding, then it is REALLY time to replace, but this is obviously not to that stage yet...
#2 ·
ddix,
Anyone feel free to correct me on this but I think brake pads nowadays are manufactured in such a way that they will consistently make a high pitched noise when nearing the end of service life. By consistently, I mean not only in the morning when you first take it out but just about every time you step on the brakes.
Here's a nice article on the subject:
http://www.edmunds.com/ownership/howto/art...87/article.html
Hope that helps!
-N- :thumbsup:
#3 ·
Most brake pads today come with wear indicators that will rub on the rotor and make a high pitch squeal. I usually do not wait for this to happen. The best thing to do is change the brakes when the pads are down to 1/16" if they are bonded or 1/8" if they are riveted.
As for the rotors, metallic pads eat away at the rotors making grooves, you will need to turn them so they provide a smooth braking surface.
#6 ·
Originally posted by dogstar@Sep 20 2007, 02:06 PM
This should not be the case, at least it has never been in the cars I have owned or worked on. (Way too **** many)
[snapback]109363[/snapback]​
yeah, i thought this would only happen if the calipers were maladjusted?
as for the hight pitched squeak - that is actually what i meant by "squeal".. those are the sensors... i suppose maybe in another couple months i should have the pads replaced (since I dont actually know who the previous driver was or how they drove) and get the rotors turned... the pads may be down to about 1/8" by then...
also, what is anyone's thoughts on ceramic pads v. semi-metallic? (besides less brake dust)....
i know most havent necessarily had to replace their Sonata brakes yet, but given that my car was used, i almost want to start fresh with a couple things so i know how much time i have with them...
#7 ·
I swear by ceramic pads. They last longer, are quiet and no brake dust. That's all I've been using for the last 5 or so years.
