If you going to flush it out, just start at left front and pump the reservoir down to just above the master port, do same for RF, thus you wont spend all day mixing clean fluid with dirty fluid.
When bottle real low, fill it up with clean fluid, and pump the fronts until you see clean clear fluid.
Now run each rear, watching for clean clear fluid, remembering to keep reservoir full of clean fluid
Now hit the front a few shots and all be done
I take them out back and stand on brake pedal to make ABS cycle and work the pump in the Hydraulic Unit, both forward and reverse
