accent customization WIP
2.9K views 21 replies 4 participants last post by  Hueydriver
accent customization and upgrades progress since 2018.
just an experiment where i sanded the tail pipe to a mirror finish.
insulation foam for sound deadening. I would later put on a (new hood)
aftermarket rims
painted door panel with vinyl paint
LED headlights
painted engine cover urban camo with stencil I drew and cut out.
when I first got the rims. which I painted btw.
#9 ·
I removed all the factory speakers and tweeters and swapped them all for Pioneers. I do not know how to install subs and amp and wiring and ****, but I desoldered the factory connector on the old factory speakers and soldered them onto the new speakers and they work fine, and I had them like that for 5 years so far. the tweeters however came with little capacitors you gotta solder them to but that was easy.
#10 ·
I changed the old brake rotors and brake pads for drilled and slotted rotors and Akebono brake pads that Scotty reccommended. Still going strong 5 years later.
The old Rotors and Brake pads
Oh yeah, and I painted my calipers with VHT high heat paint. Primer, paint, clear. All high-heat rated.
#20 ·
Metal Fuel door off of a 2009 that fits my 2008 and replaces my plastic fuel door. I stripped it to the bare metal and polished to a mirror finish as me==best as I could. I have not installed it yet because I feel I can get a better shine & I'm going to redo it.
I had it disassembled for sand & polish
