Threw a code tied to the downstream O2 sensor. The O2 wires go into a rubber grommet under floorpan, under the front passenger seat. I popped it off expecting to see a connector, but the wire just continues. It is under the passenger seat somewhere.
Where is the connector located, and how do you get to it to replace the sensor?
Chat GPT said to pull the plastic cover on the door sill and peel up the carpet, but that doesn't seem right... or at least is missing a step.
This is the downstream sensor by the cat. Thanks.
