2022 Tucson Map Sensor
1.4K views 5 replies 3 participants last post by  Reeseg7
Hello anyone here own a newer Tucson or know about cars that can post of picture of where the map sensor is located at?
I have a 2022 Tucson limited trim and I’ve searched everywhere on the internet and have found zero results! I’m going to try to replace it myself. Wish me luck!
#5 ·
Can also just blow into the sensor hole, maybe got clogged with dirt. it's a hole to the sensor that read the atmo pressure
How would a MAP sensor get clogged with dirt? It's constantly being exposed to a vacuum. And vacuum literally sucks. So it would pull dirt out of the hole, not push it in, which is what blowing into the hole would do. And blowing is exposing the sensor element to a pressure it was never designed to measure. Not a great idea, IMO.
My car is throwing a code and it has to do with the map sensor.
P0106?
Have you had a flat battery, or had it disconnected for any reason?
#6 ·
P0106?
It showed P2074:
Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Higher Load
I removed both the map and maf sensor and used the proper cleaner and sprayed both down. Running well now but if it throws the same code most likely need to replace either sensor.
