2011 Santa fe remote start quit working
4.3K views 6 replies 4 participants last post by  VKennedy
My 2011 Santa fe remote start quit working. Is it possible to replace the inside component (small black box with antenna) behind rear view mirror, at least that's what I was told, or am I being overly optimistic?
#5 ·
OK here is the way you can activate and deactivate your factory command start.
Hold both the lock and unlock buttons at the same time for about 5 seconds.
You will see the park lights flash.
If your command start was activated now it will be deactivated.
If your command start was deactivated now it will be activated.
I have had it change from activated to deactivated and vice versa once in a while.
No sense in replacing anything till you know its not activated.
