My 2011 Santa fe remote start quit working. Is it possible to replace the inside component (small black box with antenna) behind rear view mirror, at least that's what I was told, or am I being overly optimistic?
Takes Steve's advice clean up every ground surface to metal and most issues magically disappear. Just make sure you add some fluid film to prevent rust. I had been dealing with electrical gremlins in our 21012 for the last 2 years.
OK here is the way you can activate and deactivate your factory command start.
Hold both the lock and unlock buttons at the same time for about 5 seconds.
You will see the park lights flash.
If your command start was activated now it will be deactivated.
If your command start was deactivated now it will be activated.
I have had it change from activated to deactivated and vice versa once in a while.
No sense in replacing anything till you know its not activated.
Thanks very much for all the great advice, greatly appreciated.
Related Threads
Hyundai Forums
posts
1.9M
members
465K
Since
2004
Hyundai Forum is a community for all Hyundai Owners to talk and learn all about their favorite subject: Hyundai cars from the Sonata to the Elantra and even the new Kona!
