Hi, 2008 Accent with 118k miles.
2 wks ago sluggish to start and loss of power while trying to merge on freeway. took to shop and they recommended replace crankshaft and camshaft position sensors ($700) and timing belt/ water pump ($1200). Shop was unable to recreate loss of power.
I replaced the camshaft and crankshaft position sensors, but still have check engine light on. (parts bought from amazon, not OEM though). Bought a code reader and it recommended change oil control solenoid, which I did. Still have CEL on. Car starts easily, runs smooth, accelerates smoothly.
Unable to clear code using code reader. P0014, P0014 code in a Hyundai Accent indicates a problem with the camshaft timing in the bank of cylinders that contains cylinder 1 and is in the exhaust, rear, or right position.
suggestions?
thanks in advance!
suggestions?
thanks in advance!
