I went to the movies and came out 1 1/2 hours later. I walked to the car, used the key fob to unlock doors and got in car. I put key in, turned power on but didn’t start the car. I rolled down the windows, responded to two text messages and then I tried to start the car. When I turned the key nothing happened. It was like I had a dead battery. All the lights on dash worked and door chimed. I tried a few times and then it basically drained out all power so it had no lights or door chimes. I tried to jump start the car. When I hooked up cables I got no door chimes or lights and car wouldn’t start. The electric mileage indicator wouldn’t even come on.
I had car towed to a garage. They said the battery was fully charged, had 843 cold cranking amps. They said the starter was getting power and they said alternator was good (not sure how they checked that without taking it off).
The garage replaced the main relay, ignition switch and ignition cylinder. Still no change.
Does anyone have any idea what I can try?
Reply
Reply
