20001 Santa Fe Idle Problems
2.6K views 6 replies 4 participants last post by  lovemysantafe
Hi my santa fe will not do it as bad when it is in park just bc the idle is alittle higher, but when i put it in drive the car will sputter pretty bad. It will do it worse at times and idle good at other times. There are no codes present. Any help would be great. The car runs great while driving.
#4 ·
I had the same problem with my 2005. I took it to the dealer a couple times and the problem would not go away for several months. Occasionally the check engine light would come on but after shutting down and restarting it would automatically clear so no codes when at dealer. It did not run rough all the time but you could guarantee it would act up at least once on any trip longer than 30 miles or so. Eventually it got worse and the engine light stayed on(this time it got towed in to dealer). It turned out to be a faulty O2 sensor. Now it's running like new again...FINALLY! Good luck! Hope you get yours figured out.
#7 ·
I know some fundamentals but what you're getting into here is pretty advanced stuff. There are many things that could be causing this and my personal opinion would be to take it to the dealer and let them diagnose it properly.
Maybe somebody else will pop in to donate some more helpful advice but that's about where I stand. Best of luck to you. :grin:
