Guys, I'm looking to buy this amplifier this week. Can anyone make a comment on how good this will be? I plan to use it bridged 4Ohm for a 10" enclosed sub. Also, can you suggest a good sub to go along with this? Thanks....
Power Acoustik BAMF1250/2 Car Audio 2CH 1250W Speaker Amplifier
220W x 2 @ 4 Ohms
280W x 2 @ 2 Ohms
560W x 1 [Bridge] @ 4 Ohms
Die-Cast Aluminum Chassis
• Jet Black Texture Coat Finish
• Gloss Black Plexiglas Top
• Front Edge Pre-Amp and Connections
• Top Mounted Protection Indicator
• Chassis Integrated Mounting Feet
• All MOSFET Transistor Amplifier
• Regulated PWM Power Supply
• Three-Way Protection Circuitry
(short, thermal & overload)
• Hi/Low/Subsonic Crossovers
• Pre-Amp Outputs (ex. 1200/4)
• 200mV-6V Low Level Inputs
• Direct Input 4 ga. Power & 8 ga.
Speaker Terminals
2/4 Ch. Features
• 2 Ohm Stereo, 4 Ohm Bridged Stable Class A/B
• Tri-Mode Capable
• Variable 12dB 30-250Hz LPF
• Variable 12dB 50-500Hz HPF
• Variable 0-12dB 45Hz Bass Boost
• Variable 12 dB 15-50Hz Subsonic Filter
(ex. 800/2 & 4ch. models)
• Frequency Response: 10Hz - 30kHz
• Signal-to-Noise Ratio: 97dB
• Total Harmonic Distortion: .02%
• Dash Mount Remote Gain Control (2 ch. models)
Mono Block Features
• 1 Ohm Stable Class D
• Variable 12dB 40-200Hz LPF
• Variable 12dB 20-50Hz Subsonic Filter
• Variable 0-18dB 45Hz Bass Boost
• Frequency Response: 15-150Hz
• Signal-to-Noise Ratio: 100dB
• Total Harmonic Distortion: .5%
• 180o Phase Switch
• Bridged Synchronization
(strap amps together for double power!)
220W x 2 @ 4 Ohms
280W x 2 @ 2 Ohms
Speaker Terminals
2/4 Ch. Features
• Tri-Mode Capable
Mono Block Features
• 180o Phase Switch
