Variant Code
3 reading
79K views 182 replies 82 participants last post by  gabgrullon
Hi,
Does anyone have a way of getting the correct Instrument Cluster Variant code for a Tucson
I wish to add Music to the info screen on the dash, I know it can be done but need the variant code to enter
If anyone can do this, I'll supply all the options the car has, as I know these must also be calculated
Cheers!
#170 ·
Hello, i'd like to request a ESC Variant code of my vehicles.
1. KMHN3411BPA046403
2. KMHN3411BSA084634
both vehicle is same GN7 HEV, but one of vehicle has an issue with ESC behavior with suspension.
the code will be very helpful to diagnose the issue that which part has issue.
thank you so much, have a great day :)
#179 ·
Hi all
I have a 2014 Hyundai Accent which has the Abs error which is displayed on the cluster.
Thanks to Autosparks help as well as another forum user's post, I've established that there are no Abs Fuses blown, the abs module is getting the correct power to it. The abs pump and module was also bench tested by a repair centre with no issues found.
Scanning the car again, shows Error code C1702 which now indicates that I need the appropriate variant code for the Hyundai accent for the ecu to communicate to the abs module
Vin is : KHMCU41DLEU684104
Hoping that someone has the info I need and that I can avoid going into a dealer
Thanks
Neren
