USB using Android Smartphone
23K views 17 replies 11 participants last post by  n1rav
Hi everyone,
Recently purchased a 2014 Hyundai Elantra Limited.
I wanted to ask if anyone knows a way to get music working via the USB port in the elantra. It works great using an iPhone but not Android.
I am using an HTC ONE running Android 4.4
Is this possible or will I have to just use Bluetooth.
Thanks.
#3 ·
If I'm not mistaking, Bluetooth works better for Android. You probably won't get meta tag data, but you should still be able to use the arrows on the steering wheel to go move through your music library.
All 2013's and up (or 2011/2012's with the "Audio 3.0" headunit like myself....) should support both iPhone and Android controls over Bluetooth. (Unrelated, it also will use a normal USB to plug in your iPhone without a stupid adapter.)
#6 ·
Whenever I connect my old iPhone which I use as a iPod now a days, it connects and then keeps reconnecting constantly, as for my HTC One, it says connecting and then says error. So I just use AUX.... Bluetooh I was using for a while but sound was lower compared to AUX. I prefer it louder than what the blue tooth offers.
#10 ·
I've much preferred using a Sandisk Cruzer Fit USB drive in my '13 which contains all the music I care about. It stays plugged in 24/7 and is always available when I drive, doesn't use my cellphone battery, displays all the Meta Data tags, and is pretty much invisible while in use. I tried Bluetooth with my HTC One X, and was not impressed with the audio quality.
#13 ·
I'm with you, I prefer a usb drive with all the music - easy to add/update and just leave it plugged in all the time. No need for cables and crap to connect to the phone (plus I don't want my phone tethered anyway). And BT is just a pain to have to set up every time, choosing media or pandora or whatever means having to go into phone to select it etc.
As for BT, it's come a long way - very good codex now for higher quality sound as long as you're using the 3.0 or 4.0 standard. The aptX codex is the standard, too bad it's not in Apple's iOS (so sad Apple fanboys, but to be fair it is supported in Mac OS X). Good read here, among many on the 'net:
Does Bluetooth Audio Still Suck?
#18 ·
USB Advantages
I agree that USB drive or Bluetooth might be better than plugging your phone via usb cable but...
Some advantages of using your phone with USB
1. Phone will charge while listening to music
2. You can play audio streaming apps (pandora etc..), put that smartphone to use
3. USB with the iPhone gives album art, track/artist info, song time progress bar, play/paus, previous, next buttons (this is a much richer experience)
Has anyone figured out a way to atleast connect an Android Phone via USB? I have the HTC ONE (with Android 4.4), so there is no mass storage option.
If someone knows a way, please advice.
