Turbo Solenoid Error Code P0299 at 60100 miles
5.2K views 3 replies 3 participants last post by  Dog Patch Steve
I got a check engine light and loss of power at 60,100 miles on 2017 Tucson 1.6 Limited. Dealer charging $500 to fix and not covered under warranty since over 60,000 miles. Any suggestions? Thanks.
#2 ·
$500 to "fix" what ?
Turbo on the engine is weak,, seen a few with fan on the hot side broken off and rattle around inside turbo housing.
had 1 that oil tube gooped with gelled oil, seized turbo,, replace engine and turbo,, was back recently for turbo, neighbor got to do it.. I just did 1 that had hot side fan broken, nuts loose that held unit to head, then the studs broke when using torque wrench.. regards to you
#3 ·
Had the same acceleration issues with my 2016 Tucson Sport 1.6 Turbo. Used a scanner a got a P0299 error...Turbo charger issue. Hyundai diagnosed and found the Actuator Rod was stuck and the whole actuator system needed to be replaced. They replaced the Turbo wastegate actuator... $200 part plus about $400 labor. Car accelerates like it's brand new. Also the hurky-jerky start-ups in first to second gear have dissipated tremendously. Almost a pleasure to drive now. Now if that stops the engine from guzzling a QT of oil every 1k miles I'll be really happy.
