Thank you for posting this, looks exactly like the one I am finding on my Limited USA model. Didn't spot that two terminal connector at first, is located at the bottom of the thermostat housing, and I gather that housing is replaced with the thermostat. And because it is, would put the cost of this part in the 50+ buck range.
Sure looks like a conventional wax bellows thermostat and with that casting sticking out the side of that spring, looks like a fail safe. So what is that connector for? Two wires, on other similar thermostats of this type, is for a heater. What I don't like to see this that O'ring type gasket, turns into powder over time and leaks, use to use a gasket for these with gasket maker on it, would last forever.
Takes me at least 0.3 hours to find my car keys, have to drain the radiator, and preferably the block as well, make sure your dog is no where near around, they like that taste of the coolant, no good for them or yourself for this matter, causes kidney damage. Been years before I could even come close to removing the block drains, even on my 454 engine in my motorhome, mounted right behind the motor mounts, no way to get those out. Can barely get them out on my 305 in my boat, have to or next spring will have a cracked block, more than a two buck repair. Was on a boating site where many others didn't know this, had to get off that board.
So suspecting some spillage by removing this thermostat. Looks like the alternator has to be removed first even to get at it. But not as bad as a 86 Honda Civic I had, had to remove half the engine to get at that thing, wasn't the best way to spend a Saturday.
Feel 0.3 hours is about right to change this thermostat, but this is with a dry block sitting on your kitchen table. Watch out for those AC lines, one slip of the wrench will give you even more problems.
Really liked see a radiator cap again, all neoprene hoses, and a pressure free overflow reservoir. A lot of this new stuff is using plastic hoses, recovery tank or whatever they call this thing, sees the same pressure as the rest of the system and upped from 15 psi to 25 psi. And have tossed plastic food containers much stronger than this POS plastic they are putting on these things.
Is this thermostat covered under that 10 year warranty?
