Yesterday when I entered the car and started it with the digital key, it would not actually start. It kept giving me a message that I needed to switch from N to P to start the car. The problem is that it was already in park. It kept flashing P and when the push to start button was pressed it would display to put the vehicle in P to Start. I tried everything I could to try to get in gear. It wouldn't even shut the car off entirely.
I thought about disconnecting the battery but to my surprise the battery is nowhere to be found in the engine compartment.
I then thought about pulling the fuse for the e shifter. The problem is this is part of an integrated fuse block. If it happens to you, there is a smaller 10 A fuse that is also labeled e shifter. And the battery is actually in a plastic compartment in the trunk area next to the jack.
I also called blue link and the local dealer. Neither was helpful in helping diagnose or resolve the problem. Both said that they never heard of the issue. The only offer from blue link was to tow it to the same local dealer I had called.
When I pulled the small 10 Amp fuse, lights for the reverse sensors malfunctioning came on. I replaced the fuse and the car was then able to switch to gear as normal.
