hey guys quick question...my 2001 accent 4dr will start up no problem when everything is cold, but once i let it idle for about ten to fifteen minutes and if i shut it off, it will start back up but then it stalls and wont start back up, or if i just let it run a little bit longer it also stalls, no problems with fuel pump or relay when it is cold it starts right up, but once it stalls it wont turn back on....the pump is getting power even when its hot so could it be a bad wire or should i test the coils when it gets hot or am i completely looking at the wrong thing?
