Have a 2016 sonata eco noticed a sound coming from the back upon closer inspection it appreared to be in the gas tank is it the fuel pump going bad? Where is the entry to the fuel tank located any repair manual online
A bit soon for the pump to go bad, unless the car was often times driven low in gas. A faulty pump does not necessarily make more noise, may try simply turn the ignition to Acc without starting the engine, the pump should prime 1-2 seconds making a whirl then stay quiet. May use a scanner to read the pump duty cycle
Check to see if there is a TSB or extended warranty on the fuel pump. The 2.0 and 2.4L have 15 year/150,000 mile warranty on them.
See my thread HERE.
Related Threads
Hyundai Forums
posts
1.9M
members
465K
Since
2004
Hyundai Forum is a community for all Hyundai Owners to talk and learn all about their favorite subject: Hyundai cars from the Sonata to the Elantra and even the new Kona!
